Putting A Lighted Switch In A Non-grounded Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 04:15 AM   #1
Putting a lighted switch in a non-grounded box
Is it possible (and/or safe!) to put a lighted switch into a box that doesn't have a ground wire (i.e. a switch loop with just the hot from the panel and the hot to the light in the box)?
AFAIK this is a switch that lights all the time - even when the light is off. Although, it has only two brass (hot) screws and a green ground screw (which I can't connect as I said)...
If it IS safe to do this, will the light in the switch work?
fm
fdmillion is offline   Reply With Quote
Old 01-27-2010, 06:19 AM   #2
Remodeling Contractor
yes it will work
Old 01-27-2010, 07:26 AM   #3
Licensed electrician
Rewards Points: 1,462
Check to see if the switch needs a neutral. Some do.
Old 01-27-2010, 12:26 PM   #4
Rewards Points: 1,492
A switch that lights up only in the "off" position will work where any regular switch was installed.
(There are some idiosyncrasies if the load being controlled is of very low wattage for example is a compact fluorescent.)
A switch that lights up in the "on" position requires a neutral or may be using the ground which in today's world is improper. If it lights all the time, it will light up only in the "on" position if you exchange the wires on the switch terminals.
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
