Pushmatic Panel, No Main, No 2.p. Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 09:12 PM   #1
Pushmatic Panel, no main, no 2.p. breakers
My home was built in 1955 and was outfitted with a 100a "bulldog"-pushmatic panel. I have been told that it is a split bus panel, but I am confused, there are no 2.p. breakers in the panel, which may feed the bottom portion. I can't find another means of disconnect, other than removing the meter. Is it possible that the "split bus" was abandoned at some point and the panel will be hot unless the meter is removed. Any help is greatly appreciated.
avery2008 is offline   Reply With Quote
Old 09-23-2008, 09:56 PM   #2
Licensed Pro
Double pole Pushmatics are side by side, not top/bottom. Check again to see if thee is not one present
Old 09-23-2008, 10:03 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The other thing with pushmatics that the double pole breaker the handle will be a crossover type { sorta like bridge } and it will be big and ya can't miss that by Kilometers
Merci,Marc
Old 09-23-2008, 10:15 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
2 pole bulldog are like this image as househelper and Marc have said....
Old 09-23-2008, 10:19 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
A single pole pushomatic breaker has a smaller push button than the 2 pole, and will be close to the centerline of the panel. A 2 pole has one larger button directly in the centerline...and like Marc said, is a crossover/bridge type.
Kyle
Old 09-27-2008, 06:25 AM   #6
Pushmatic Panel
Thanks. I have determined now that I do not have split bus panel, I was told that their would be a noticeable gap, which there is not. I have double and triple checked, there are no double poles. The meter is located approx a total of 5-6' from the panel and there is no means of disconnect. I am currently rewiring the house, but when it comes time to switch out the panel I think I will leave it up to the pro's. Have a great weekend.
Old 09-27-2008, 08:07 AM   #7
Rewards Points: 338
avery2008, Wise idea to have that Pushmatic panel replaced. In some areas (like here on Long Island) those breakers are hard to find. When you do, they're expensive ie. $70.00 for a 2 pole 30 amp vs. about $9-10 for a "regular" breaker. Good luck with your rewiring.
petey_c is offline   Reply With Quote
Old 05-02-2009, 02:11 PM   #8
Pushmatic Panel
I just replaced my Bulldog Pushmatic panel. I have 10 X 15A, 1 X 30A, 1 X 40A breakers if you need any?
kkachkowski is offline   Reply With Quote
Old 05-02-2009, 02:51 PM   #9
Bigplanz's Avatar
Rewards Points: 990
My split buss panel looks like this. It was installed in 1977. I have been told (don't know for sure) that the double pole breaker at the top of each column controls the single pole breakers at the bottom of that column. I have also been told that the double poles in that column will stay hot, as will the other column. Please correct this information, as needed, as I cannot attest to its accuracy.
Bigplanz is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
