Pushmatic Panel Layout - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 10:25 AM   #1
Just call me Andrew
Rewards Points: 1,020
Pushmatic panel layout
I am going to be installing some home automation stuff for my parents. They have an early-'70s Pushmatic panel.
Does anyone know (or have a decent guess) if those panels are laid out like newer ones...specifically...does every other breaker (vertically) use a different leg of the electrical supply?
Thanks!
Andrew
secutanudu is offline   Reply With Quote
Old 09-07-2011, 10:37 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Left hand and right hand busses. Breakers on the left all use the same buss, same on the right side. 2-pole breakers straddle the center to use a buss from each side, as in this picture.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
secutanudu (09-07-2011)
Old 09-07-2011, 10:38 AM   #3
Just call me Andrew
Great, thanks. I hope the two circuits in question are on the same side!
Andrew
Old 09-07-2011, 11:07 AM   #4
Just call me Andrew
In case anyone is interested why I am asking this, the automation stuff sends commands over the power lines to control devices...
For 2 devices to talk to each other, you need either:
-The devices on the same leg
or
-The 2 legs need to be "bridged" by wireless RF devices to jump the signal from one leg to the other.
Andrew
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
pushmatic metered panel grghrnndz Electrical 1 11-16-2010 08:52 AM
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 03:22 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
