Pushmatic Metered Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 01:16 AM   #1
pushmatic metered panel
i am instaling a new panel in home .on the old panel wich is a pushmatic metered panel i only see a neutural feed coming from meter to neut bus but no hots it seems like the bus bar comes in from meter above edison is coming to unlock meter will i find the hot feeds when i take the meter out or will i have to suply them thanks greg
grghrnndz is offline   Reply With Quote
Old 11-16-2010, 07:52 AM   #2
Mad Scientist
Typically those meter socket and panelboard combos will have the bus bars running up into the meter compartment and connected directly to the meter socket. If you're replacing this panel, you'll have to install a new meter socket as well.
McSteve is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Pushmatic Panel, no main, no 2.p. breakers avery2008 Electrical 8 05-02-2009 02:51 PM
Need to replace Pushmatic panel? ohfreddie Electrical 1 08-27-2006 04:25 PM
