Pushmatic Breaker Won't Seat - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 11:14 AM   #1
Pushmatic breaker won't seat
Hello-
I have researched this online and can't seen to find any info...the pushmatic panel I have (yes I do know all the problems with pushmatic) needs a larger 2 pole breaker for a new water heater I installed. I have plenty of replacemnet breakers so I popped out the 20 amp and tried to replace with a 30 amp but the 30 has 2 little stubs on the base of the breaker that bump in to 2 screw on offsets in the panel.
Can I remove the offsets so the breaker will seat? They are obviously there for a reason but the larger amp breakers all have these little feet that the 20 amp 2 pole and all single poles don't have....
And yes a new panel is in the future...but a foundation takes priority.
Thank you for any info
Jim
jb503 is offline   Reply With Quote
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
Help: Breaker won't fully seat davidy123 Electrical 14 04-15-2008 10:10 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
