Old 02-15-2013, 09:57 PM   #16
747
registered
747's Avatar
Pushmatic
Originally Posted by Oso954 View Post
Many of the pushmatic panels are a split bus design. They often do not have a single disconnect or breaker that kills the entire bus.
I knew this.:: Be extremely careful. You have pro sparky's show up see one of these and say there went my day.
747 is offline   Reply With Quote
Old 02-15-2013, 11:01 PM   #17
Pushmatic
I had pushmatic boxes in a building once, my electrician told me that they should be replaced at the earliest possible time. Something about the breakers have a tendency not to trip when they should. He came close to saying that they were very dangerous. That was an opinion of his though and I'm just repreating what he said.
old_squid is offline   Reply With Quote
Old 02-16-2013, 10:37 AM   #18
Pushmatic
My father also has a pushmatic 200 amp serive I told him he must replace because I too heard alot of bad things about them, not to mention hes got that box maxed out by far. He went and bought a Siemens panel. His panel (like mine was) did not have much written on the door as to what each circuit runs so I told him to do the breaker game as to flip off all breakers and one by one turn each on and write down what each one powers exactly. The problem with his box though is that its not really long (i think 7" shorter than the Siemens so he will need wire nut mostly all the circuits in the new panel to make them longer. When I had my neighbor electrician pull out my Bryant and install a genetator ready Reliance panel it took him alittle over 5 hours and I payed him $150. He said he would do my fathers panel as well but thats alittle more in depth.
Jason34 is offline   Reply With Quote
Old 02-16-2013, 12:14 PM   #19
Licensed Electrician
k_buz's Avatar
Pushmatic
I haven't heard anything bad about Pushmatic panels, and have never suggested to a customer to replace one based solely on the name.
Location...Location...Location
Old 02-16-2013, 12:58 PM   #20
Electrical Enthusiast
Pushmatic
Originally Posted by crescere View Post
I finished this and everything works fine. I t was time consuming because I had to unscrew every outlet and switch, but I do not understand why so many thought this was a job for a pro. Actually most of the switches already had the black wire attached and when I switched the wires at the box this made them “right.” Most of the outlets had the polarity reversed except the GFCI. The only thing I nearly missed is to re wire the kitchen hood fan and light, but I caught that in time.
Glad everything went well. When just seeing a picture an older panel with some obvious wiring problems, and not knowing the electrical layout and other issues that may be present in the house, it can turn into a real mess. That is why so many were recommending an electrician to come in. Glad everything worked out though
Kyle_in_rure is offline   Reply With Quote
Old 02-16-2013, 01:33 PM   #21
Pushmatic
My father in law had a pushmatic that had to be replaced back when the electrician re-did some wiring. And like I said my father has a pushmatic and his one circuit keeps tripping every now and then even if there is no load on it. The guy that upgraded my panel said pushmatics should be replaced.
Old 02-16-2013, 02:03 PM   #22
k_buz's Avatar
Pushmatic
Did the guy making the recommendation stand to make a profit?
The Following User Says Thank You to k_buz For This Useful Post:
NJMarine (02-16-2013)
Old 02-16-2013, 03:23 PM   #23
Pushmatic
When I did houses for a E.C. we used P-matics and we just stripped and put a straight wire under screw.Mind the side you place it in.You want to have in the clockwise side.
bobelectric is offline   Reply With Quote
Where can Pushmatic breakers be bought? peterthomas3 Electrical 15 12-03-2012 10:11 AM
Fake Double Pole Breaker in Pushmatic johnk88 Electrical 17 03-01-2011 11:37 PM
Pushmatic breaker won't seat jb503 Electrical 0 05-31-2010 11:14 AM
Pushmatic load centers speedster1 Electrical 3 01-02-2010 07:55 AM
Need to replace Pushmatic panel? ohfreddie Electrical 1 08-27-2006 05:25 PM
