Push In Connectors - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 03:45 PM   #31
Ravenworks's Avatar
Originally Posted by Msradell View Post
Not quite, I'm originally from New York and then lived in South Carolina before moving to France and finely Kentucky. If you know anything about the codes in the Chicago area he would certainly agree! They are some of the most backward and not consumer friendly codes in the United States.
So what part of that has to do with you bashing the unions?
I was in agreement with your post until you started bashing.
Go to the library and read a book on labour history.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 06-13-2012, 03:49 PM   #32
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I am afraid of what this is going to turn into, but I'll just say, history is just that, history.
The unions had their place and now are just bloated organizations riddled with corruption, elitism and even crime.
The union CANNOT stand on it's "Look what we did for the workers of this country" justification any more.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Msradell (06-13-2012), rjniles (06-13-2012)
Old 06-13-2012, 04:08 PM   #33
Msradell's Avatar
Rewards Points: 170
Agreed! The only thing they do his increase prices!
Msradell is offline   Reply With Quote
Old 06-13-2012, 04:21 PM   #34
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Semi-Retired El View Post
Since an AHJ has the final say, if done legally, does your Jurisdiction ever go tighter than the Code?
Here in New Jersey we adopt the NEC through the UCC with certain modifications. None of the modifications are more stringent then the NEC, and in some cases are less. One example is we are still using some of the exceptions from 210.8 of the 2005 NEC. As for the final say, it doesn't quite work that way here either. If the EC or HO disagree with the EI then the EI can issue a Notice of Violation. On the NOV it will state that individual can take his case to the county Construction Board of Appeals (which is made up other inspectors from each dicipline and an Architect). If the BOA rules in favor of the EI then the case can be taken to the state BOA, and then to court. WIthout really going into depth here, it is safe to say that the EI does not have the final say. Unfortunately, all work stops until everything is resolved.
I have posted a lot of information about how New Jersey works in this post. If anyone wants more information, pm me.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-13-2012, 04:25 PM   #35
electures's Avatar
That's just it. The AHJ does NOT have "the final say". WHY do so many people think this.
He CANNOT just say "That is not allowed because I don't like it."
This is correct. Please see the above post.
Old 06-13-2012, 04:57 PM   #36
Code05's Avatar
Rewards Points: 1,104
Enough of the union talk, pro or against, it has no place in a DIY forum.
I believe that we were discussing wagos or push in connectors.
If we digress and bring up different electrical codes, let's stick to codes.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Jim Port (06-13-2012)
Old 06-13-2012, 06:37 PM   #37
Semi-Pro Electro-Geek
Rewards Points: 2,922
Also, the inspector is not the AHJ. The AHJ is the municipality, which employs the inspector to do the first-level code enforcement job. Codes are laws, indirectly. A court has the final say. The inspector himself isn't the ultimate authority on anything.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Speedy Petey (06-13-2012)
Old 06-13-2012, 07:09 PM   #38
That's why I said the Jurisdiction can modify the NEC anyway they feel like, If done legally.
The NEC is not a code enforcing agency. They come up with what they feel is a good set of rules and each jurisdiction adopts or rejects all or any part they wish.
We're a nation of laws and 90.4 states it very clearly.
Art 100 also states: " The AHJ. An organization, office or individual responsible for enforcing the requirements of a code or standard, or for approving equipment, materials, an installation, or a procedure.
Semi-Retired El is offline   Reply With Quote
Old 06-13-2012, 07:19 PM   #39
Rewards Points: 1,492
Backstab connections on receptacles, etc. also have a flat metal plate and a spring to make contact with the inserted conductor.
If the wire end is not perfectly straight, it will contact the plate only at a few points as opposed to make a continuous line contact. In addition, as the wires are pushed into the box to finish the job, it is possible for stress on a solid wire to cause the end to separate from the metal plate inside the push in connector leaving just one tiny spot of contact.
Screw activated clamp type back connections as well as side terminal screws flatten the wire enough to make a continuous line contact.
Old 06-13-2012, 07:39 PM   #40
electures's Avatar
Here in New Jersey one of changes the UCC makes to the NEC when it is adopted is to substitute words "Electrical Subcode Official" in place of AHJ throughout the entire. This means that the term AHJ has no legal standing in New Jersey. The Electrical Subcode Official is an individual as in a person and can also be the inspector. Oooh! Post #600. woot.
Old 06-13-2012, 08:02 PM   #41
Which is further proof any jurisdiction can accept the NEC, reject the NEC, modify any part of it, make up their own Code etc.
And, they can name any group, individual etc. to enforce it.
If an electrician, butcher, baker or indian chief doesn't like any part of it or what the "enforcer" says or does he/she can take it all the way to the Supreme Court, on their dime.
Old 06-14-2012, 11:54 AM   #42
electures's Avatar
Don't know about that, but here in NJ it stops at one of the low level courts.
compressing RCA male connectors onto RG-6 cable amakarevic Electrical 0 01-03-2011 02:49 PM
push in connectors BlueBSH Electrical 8 04-01-2010 11:01 AM
Is it acceptable to use push connectors AND screws on a duplex receptacle? Bob K. Electrical 5 03-07-2010 07:14 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 08:26 PM
What do you think of the push in connectors? jamiedolan Electrical 30 11-16-2008 02:13 PM
