Push In Connectors - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 01:15 AM   #16
Semi-Pro Electro-Geek
Rewards Points: 2,856
Originally Posted by Semi-Retired El View Post
IMO the "pinch" connection would not survive a dead short on a 20A breaker so if I left them in a fixture it would be the connection to only that fixture, not a feed-thru.
I have two data points that say otherwise: A dead short on a 20A 277V lighting circuit out of a panel with 22kA fault current available, and the connectors were fine. Also, a dead short in a 20A 480V water heater circuit (at the end of about 150' of #12) and everything survived with no damage.
mpoulton is offline   Reply With Quote
Old 06-12-2012, 08:15 AM   #17
Licensed electrician
Rewards Points: 1,020
My main reasons for asking an inspector about them would be to find out if the local jurisdiction has legally banned them or have others had problems with them.
They're a close "cuzzin" to "back-stabbed receptacles which IMO are nothing but trouble, but are still legal w/ #14.
While the concept is the same, the methodology to accomplish the connection is quite different. The push in connector has a flat surface in contact with the conductor for the entire stripped length unlike the backstab where you only have the edge of the spring in contact with the conductor. I would think a testing lab has subjected the connectors to fault currents as well as high continuous loads to ensure the connectors did not melt down.
Old 06-12-2012, 08:18 AM   #18
Did you dis-assemble the connectors to see if they was missing metal?
Semi-Retired El is offline   Reply With Quote
Old 06-12-2012, 08:29 AM   #19
Some brands have a clear shell and you can see the spring material. This allows you to ensure the conductor is fully inserted.
Old 06-12-2012, 08:29 AM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Here's my take.
Years ago the company I worked for had a customer who was a suit for Gardner Bender. We became a way of testing their new products. One of the products were these type connectors. We had many, many failures. Over the years, I am fairly certain they have worked out the design flaws and some people swear by them, but I am still a little bit hesitant to fully support them.
Other than just my basic feelings towards them, I prefer wirenuts. I have read that some of these style connectors are one time use. I would hate to have to snip all the wires, or struggle removing all the wires just to meter something. Which brings up the next point, metering splices. Much easier with a wirenut than with a full Wago.
I think I could see myself using a larger Wago for pigtailing grounds, but I don't see myself using them for much else.
Old 06-12-2012, 08:33 AM   #21
There are also test ports to allow a probe to be inserted even with all the ports filled.
Do you reuse wire nuts?
Old 06-12-2012, 08:34 AM   #22
k_buz's Avatar
Very often. Now is when you tell me that they also say not to reuse.
Old 06-12-2012, 09:17 AM   #23
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I felt the same way when I first saw them. Looking at it from my stand point as an inspector, if it listed and labeled, and installed per the manufacturers, I have to accept it. I do not have the luxury of "because I said so", and any inspector who thinks that way is ignorant. It doesn't always make me popular, but I am respected.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-12-2012, 11:38 AM   #24
Rewards Points: 58
Originally Posted by Msradell View Post
Everything you've posted to be taken with a grain of salt by everyone else. You are in Chicago and everything in Chicago is backwards and done to make things more expensive and requires several different union trades to do anything! Someday maybe you guys will catch up with reality and not require conduit for residential use, allows things that have been standard everywhere else in the nation for decades and realize that unions are no longer better than anyone else.
Another Appalachian hillbilly that has no clue.
Old 06-12-2012, 12:59 PM   #25
Rewards Points: 590
I don't reuse wirenuts. The reason is that about 25% of the time, when I remove one that is well-torqued, the spring falls out. I figure that there's no need to be cheap over an inexpensive item by retaining it the other 75% of the time it doesn't fail.
operagost is offline   Reply With Quote
The Following User Says Thank You to operagost For This Useful Post:
jbfan (06-12-2012)
Old 06-12-2012, 01:59 PM   #26
Msradell's Avatar
Rewards Points: 84
Not quite, I'm originally from New York and then lived in South Carolina before moving to France and finely Kentucky. If you know anything about the codes in the Chicago area he would certainly agree! They are some of the most backward and not consumer friendly codes in the United States.
Msradell is offline   Reply With Quote
Old 06-13-2012, 12:42 AM   #27
No, but we pulled a couple out of the boxes and looked at them because we were concerned. There was no visible change and the wires were held tight.
Old 06-13-2012, 08:34 AM   #28
Since an AHJ has the final say, if done legally, does your Jurisdiction ever go tighter than the Code?
Old 06-13-2012, 04:04 PM   #29
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
That's just it. The AHJ does NOT have "the final say". WHY do so many people think this.
He CANNOT just say "That is not allowed because I don't like it."
The Following User Says Thank You to Speedy Petey For This Useful Post:
Msradell (06-13-2012)
Old 06-13-2012, 04:16 PM   #30
Code05's Avatar
Rewards Points: 1,104
True, unless you are married, the question is something domestic related, and your wife is saying it. That AHJ/wife never budges.
Code05 is offline   Reply With Quote
The Following 3 Users Say Thank You to Code05 For This Useful Post:
Jim Port (06-13-2012), operagost (06-13-2012), Speedy Petey (06-13-2012)
compressing RCA male connectors onto RG-6 cable amakarevic Electrical 0 01-03-2011 03:49 PM
push in connectors BlueBSH Electrical 8 04-01-2010 12:01 PM
Is it acceptable to use push connectors AND screws on a duplex receptacle? Bob K. Electrical 5 03-07-2010 08:14 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 09:26 PM
What do you think of the push in connectors? jamiedolan Electrical 30 11-16-2008 03:13 PM
