Push On Connector - Range Element - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 02:33 PM   #1
Rewards Points: 518
Push on connector - range element
I need to replace a damaged non insulated 16awg push on female connector that is for a range element. Is it necessary to only use non insulated high temp replacements?
n0c7 is offline   Reply With Quote
Old 04-18-2012, 02:50 PM   #2
Rewards Points: 826
You should use the exact part called for and not a substitute. This is a pretty demanding application of a connector so you want to be sure to use something that meets the intent of the designers. I'd go to an appliance parts store with the model number and make of range and get the right part. This is not a good thing to "MacGyver".
curiousB is offline   Reply With Quote
Old 04-18-2012, 02:56 PM   #3
Rewards Points: 518
While I agree with you on that point you should see the genius design that shorted the connector in the first place. Nothing like a 1/2 clearance between connectors and sharp metal and a piece of insulation shoved in to protect them.
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 09:48 AM
Kenmore Oven Element Arcing Valerie1960 Appliances 2 01-30-2012 08:03 AM
Can I replace 4000w water heater element with 3800w? TitaniumVT Plumbing 6 11-30-2010 06:01 AM
Bottom (bake) element in the oven dead? elementz Appliances 3 04-19-2010 07:40 AM
Brand or OEM element in a water heater? spentonbargains Plumbing 4 10-06-2009 05:01 AM
