Push Button Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 04:17 PM   #1
Old GE hood vent. The push button light switch is broken. Had two on settings dim and bright. Pulled the switch and it has three wires. Blue Black and Orange. Light Bulb socket just has two wires. Local hardware store just has a simple push on, push off switch with two black wires. Don't know but are there three wires because of two different on settings? Really just need to turn on(bright) and off. Any way to use the two wire switch to do this? Thanks for any help.
mrduke is offline   Reply With Quote
Old 05-22-2011, 04:32 PM   #2
Lic Elect/Inspector/CPO
Black is the feed to the switch and the other are the different light levels.
If you just want bright than the 2 wire push button will work.
one lead will be connected to feed in and the other to the wire feeding the light
NJMarine is offline   Reply With Quote
Old 05-22-2011, 05:43 PM   #3
Thanks. Sounds good. I think I can do that.
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
Hi, new here and have a question about light switch in bathrooms Tazznum1 Electrical 2 01-26-2011 09:31 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
