Purpose Of 30amp Single Pole Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 01:25 PM   #1
Purpose of 30amp single pole breaker
What is the purpose of a 30 amp single pole breaker?
Giles is offline   Reply With Quote
Old 02-16-2010, 01:30 PM   #2
Licensed electrician
Rewards Points: 1,472
The only time I have used one it was for an RV hookup or a UPS for a server room.
Old 02-16-2010, 01:37 PM   #3
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
I have 2 at work in the telco demarc room, 18-30R plugs for two 208 volt UPSs. They keep our metropolitan area network running (gigabit Ethernet links to other sites in this same metro area). The telco equipment has transformers that make the 208V AC in to 54V DC to power the equipment. The UPS's plug into the wall and the telco stuff plugs into the UPS's. Both have twist-lock plugs.
brons2 is offline   Reply With Quote
Old 02-16-2010, 02:01 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I've only seen them (legally and safely) used for the things mentioned; computers/UPS/servers and travel trailers, along with commercial hand dryers.
Old 02-16-2010, 09:17 PM   #5
Rewards Points: 1,016
I recently installed one for my RV outlet - a TT-30R recept.
Old 02-16-2010, 09:30 PM   #6
Idiot Emeritus
Rewards Points: 1,492
I've seen them used for RV receptacles and point-of-use water heaters for residential.
For commercial/industrial, I've seen them used for machine control panels, generator and motor winding heaters, 277 volt parking lot lights (277 volt breaker), streetlights, an occasional piece of equipment that needs more than 16 amps, but less than 24, computer equipment, and others I can't think of right now.
The largest 120 volt single pole breaker I've installed was a 60. Most traffic light controllers have a 50 or 60 amp single pole as the main. They don't draw all that much current, (Incandescent ones are about 25 amps or so, LEDs are less than 10), but they don't want the main to trip without a very good reason.
If a pole gets knocked down, or a wire gets shorted somewhere, it'll usually blow one or more of the loadswitches out. The conflict monitor will see this, and will send the signal into flashing red. If the main were to trip, the signal would be dark. Obviously, flashing red is much safer than no lights at all.
The most common use though is because a 15 or 20 trips, and uncle Bob says 'Put a 30 in, it won't trip then'.
This usually solves the tripping problem, but creates a new, much larger problem. Generally, a fire.
Rob
P.S. I've seen maybe a dozen or so legitimate uses for 30 amp single pole breakers in houses in 20 years of doing electrical, but the big box stores always seem to have an ample supply of them. Makes ya wonder sometimes!
micromind is offline   Reply With Quote
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 11:48 AM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 05:15 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
2 pole breaker Unregistered Electrical 3 09-11-2004 11:15 AM
