Punch Outs - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 05:47 PM   #1
Rewards Points: 334
Question
Punch outs
If I have a receptical or box that has one punch-out used and I need to use a punch-out in a different location, do I need to through the recepticalor box away and use a new one or can I cover the hole with something (not sure what)?
tripower is offline   Reply With Quote
Old 02-25-2009, 05:54 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
There are filler caps you can get at most hardware/home improvement stores. They are usually available in 1/2" and 3/4" sizes. Larger sizes tend to be harder to find. Probably going to be about a dollar or 2 for a small pack of about 3-5 knockout caps. The two varieties I have seen one is a snap in cap, the other is a screw assembly that basically looks like a large washer on the outside with a small metal plate on the backside to screw into. I tend to like the screw type better than the snap in.
theatretch85 is offline   Reply With Quote
Old 02-25-2009, 05:55 PM   #3
Remodeling Contractor
metal boxes will have KO seals to cover unused openings.
Old 02-27-2009, 12:27 PM   #4
Rewards Points: 80
And you can install them from the inside of the box or from the outside. Outside is preferable.
Old 02-27-2009, 03:53 PM   #5
Rewards Points: 334
Question
I found them. Thanks. I was getting ready to ask this. It seems like the edges on these caps are relatively sharp. I was worrying if they could fray wires?
Old 02-27-2009, 03:54 PM   #6
Electrician
Use plastic KO fillers if your worried, or do what I do and bend the tabs over.
chris75 is offline   Reply With Quote
Old 02-28-2009, 01:22 AM   #7
Rewards Points: 506
I usually try to either use the existing hole, or if I can just replace the box; especially if its more than one KO hole to fill. Boxes are pretty cheap, and it just looks better not to use the filler caps, but there is a time when they are certainly necessary.
Greenlee 7310SB Hydraulic Knockout Punch Kit Help Stubbie Electrical 1 11-04-2008 11:16 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hinge drill bit or center punch? Pawl Carpentry 7 03-26-2008 10:00 PM
