-   -   Punch outs (http://www.diychatroom.com/f18/punch-outs-39160/)
tripower 02-25-2009 04:47 PM
Punch outs
If I have a receptical or box that has one punch-out used and I need to use a punch-out in a different location, do I need to through the recepticalor box away and use a new one or can I cover the hole with something (not sure what)?
theatretch85 02-25-2009 04:54 PM
There are filler caps you can get at most hardware/home improvement stores. They are usually available in 1/2" and 3/4" sizes. Larger sizes tend to be harder to find. Probably going to be about a dollar or 2 for a small pack of about 3-5 knockout caps. The two varieties I have seen one is a snap in cap, the other is a screw assembly that basically looks like a large washer on the outside with a small metal plate on the backside to screw into. I tend to like the screw type better than the snap in.
Bob Mariani 02-25-2009 04:55 PM
metal boxes will have KO seals to cover unused openings.
J. V. 02-27-2009 11:27 AM
And you can install them from the inside of the box or from the outside. Outside is preferable. :thumbsup:
tripower 02-27-2009 02:53 PM
I found them. Thanks. I was getting ready to ask this. It seems like the edges on these caps are relatively sharp. I was worrying if they could fray wires?
chris75 02-27-2009 02:54 PM
Use plastic KO fillers if your worried, or do what I do and bend the tabs over.
theatretch85 02-28-2009 12:22 AM
I usually try to either use the existing hole, or if I can just replace the box; especially if its more than one KO hole to fill. Boxes are pretty cheap, and it just looks better not to use the filler caps, but there is a time when they are certainly necessary.
