Punch A Meter Can? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 08:48 PM   #16
MarginallyQualified
Rewards Points: 2,464
Originally Posted by frenchelectrican View Post
I will give you a little tip along the way just look at the POCO website and you may have to dig a little there is a meter socket listing what they approve for their system.
They were fine with the CH panel... but he did *insist* they would only go in the bottom from an UG feed. Of course they didn't say that last week when I asked.
I am famauir with that GE box just make sure ya don't go crazy with 1 inch tandem or 1 inch two pole breakers espcally with MWBC or 240 volt load you have to pay attetion where it land in that panel.
Just two 2Pole breakers (for now)...
90 or a 100 for the detached garage and a 20 or 30 for the AC
Is any way you can take a photo what the exsting meter set up at the moment ?
Sure. It's a mess now (I didn't do any of this btw)
The 3! phone boxes and disconnect are going...
the CATV box and faucet are getting moved...
The plan is to feed the new inside panel (about 15 feet deeper into the basement) using the joist bay where the AC lines are now; maybe with SER but probably all pipe. The (new) refr line will be coming out somewhere else.
Old 01-24-2012, 09:07 PM   #17
" Euro " electrician
frenchelectrican's Avatar
I did took a hard look at that I am thinking a idea but this part may be a iffy here.
Just try this idea for a layout for new outdoor panel ( GE TM820RCUFLP ) is that from the left side of the meter what you have there now why not open that knock out opening and use the two inch ridge nipple ( short pipe ) conduit with meyers hubs on it or use the bottom left KO and use the two inch ell pipe and adjust the height of the panel which the main breaker should be no taller than 2 meter off from the finshed level then you can use the PVC conduit to run the rest to the basement.
Just a thought I don't want to make it worst than it have to be unless you are plan to put a wall there if so let me know I may have other idea along the way.
Merci,
Marc
Meter Main problem. right-sided meter? acerunner Electrical 6 07-23-2011 12:41 PM
Height of meter box Arky217 Electrical 4 05-23-2011 10:56 AM
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 09:51 AM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
