Pumptrol Square D 9013FSG2 - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 05:25 PM   #1
Question
I have a well pump that has stopped giving me any water at all. The Pumptrol box got wet and is now arching. The pin that disengages the the pump is stuck i think. The motor got a little warm but seemed normal. When I saw the Pumptrol box arching I shut off the power to it. I switched the power back on and tried to engage the box manually to see if the motor was still operational but all the box did was hum and arch. I think that there is a frayed wire or some corrosion causing this problem. If anyome has an answer, respond please. Thanks.
Blair is offline   Reply With Quote
Old 01-25-2010, 11:54 PM   #2
Master Electrician
richgriffith's Avatar
call a electrician to take care of this problem,could be several things,arcing & humming motors or parts are not good sighs. don't play around and take the chance on getting seriously hurt let the pro's take care of this one. Good Luck!!
richgriffith is offline   Reply With Quote
Problems With Atlas Shingles Roof Consultant Roofing/Siding 116 06-04-2016 05:49 AM
Duct square to round to square flow question unixb0y HVAC 2 08-26-2009 06:12 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 10:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 10:29 PM
