Pump Troubles - Do I Need To Pull It? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 01:02 PM   #1
Pump Troubles - Do I need to pull it?
I have a 1 hp Water Ace 230V single phase submersible pump. Stopped working last weekend. Bought a new controller to see if it would solve the problem. This one has the two capacitors and the overload with the switch. Hooked up the controller and put power on. Overload pops after a few seconds.
Here are readings I got:
Voltage 240V across the leads.
Resistance: Yellow/Black 3.0 ohm; Yellow/Red 11.2 ohm; Black/Red 13.8 ohm; Each color to ground ~15K ohm.
Is my pump bad? Anything else I can check?
texgolfcon is offline   Reply With Quote
Old 05-29-2010, 03:34 PM   #2
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
If your overloads are properly sized for the motor and they are tripping I'd pull the pump! It is probably frozen.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-29-2010, 04:05 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
especially since you have a new controller, I would highly suspect the pump. There is are a couple of components in the controller that, if they were bad, could cause the symptoms you have but since you have a new controller, (and presumably sized properly) sounds like it is pump time.
be sure you connected the motor correctly though. That too would cause you problems.
Old 05-30-2010, 09:54 AM   #4
Rewards Points: 240
15 K to ground is a dead short in my opinion.
Tags
pump , submersible
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
