Pump Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2013, 02:09 PM   #1
Pump Timer
I have a question regarding an in-ground swimming pool pump timer. I have a Sand Dollar SD-60 filter. I hunted all over the pump for the HP, the voltage, something that would tell me what amp/voltage timer to get. The pump is wired to a sub-panel with one 30 amp 2-pole breaker and one 20 amp single-pole breaker. I'm thinking the 30-amp breaker is for the pump and the 20 amp for some exterior receptacles.
Should the timer be wired before the sub-panel or after it between the panel and the pump? Is the amperage for the breaker enough information to tell me what type of timer to get?
ddj26377 is offline   Reply With Quote
Old 09-25-2013, 02:59 PM   #2
Rewards Points: 342
look on the motor nameplate for the specs.i would wire it between the panel & pump . that is what it is going to control.do you know what hp the motor is?kinda unusual not to have a nameplate.
circuitman is offline   Reply With Quote
Old 09-25-2013, 03:08 PM   #3
Oso954's Avatar
Rewards Points: 772
Intermatic T104R is a 40 amp 240V timer in a rainproof enclosure. About $69.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
mpoulton (09-25-2013)
Looks like it's time for a new pool pump; please advise! a1481155 Plumbing 5 08-07-2013 05:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
