Pump Relay - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 11:31 AM   #1
pump relay
My irrigation pump will not run. The relay is buzzing. Does this mean the relay is bad?
roger2386 is offline   Reply With Quote
Old 05-31-2010, 12:39 PM   #2
joed's Avatar
Rewards Points: 12,442
Probably not.
Old 05-31-2010, 02:11 PM   #3
Could mean a high resistance upstream of the relay.
If so the voltage to your pump should be rising and falling rapidly along with the buzzing [oscillating].
In this case a small, cheapie analog meter is better for troubleshooting because the needle can respond to voltage that is changing this fast. The end of the needle will look like a blur.
Old 05-31-2010, 10:10 PM   #4
Did you try taking apart the relay and cleaning it? If bugs or dust get in between the contact points or the relay mechanism it can cause chatter.
fpeftw is offline   Reply With Quote
Old 06-01-2010, 11:11 AM   #5
Rewards Points: 130
What relay? Do you have a control box for the pump system? If so what type is it and whats the serial and model number?
I am not trying to be smart about this but when you say relay, a thousand things run through my mind. If you could be a little more specific as to exactly what you have we can help you. "Buzzing" is not enough for someone to troubleshoot this on the internet unless we know more.
J. V. is online now   Reply With Quote
Old 06-01-2010, 07:42 PM   #6
the relay that he says is buzzing
Old 06-01-2010, 09:05 PM   #7
Smile
Specifically it is an OMRON 24 volt DC/240 voltAC relay G7L2a TUBJ CB!
This is in a control box for may irrigation system. It has never buzzed before and the pump has always started.
Old 06-01-2010, 09:14 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It's possibly the relay but more likely other things. The relay is $10 so if you do not have the ability to troubleshoot the system, it is a cheap attempt to fix it.
If you can do what yoyozit suggested, that would be great. If not, plug in a new relay and see what it does.
Old 06-01-2010, 09:21 PM   #9
Could also be low control coil voltage, 24 VDC coils can usually handle a drop to 19VDC before they buzz or fail to pull in.
ControlTech is offline   Reply With Quote
Old 06-01-2010, 09:55 PM   #10
will try new relay
Got a new relay coming soon. Will try that and keep you posted.
Thanks for all the suggestions.
Roger
Old 06-02-2010, 10:57 AM   #11
Roger
Keep the old relay after you get the new; with your symptoms I kinda' doubt that it is even possible that it is the relay.
Old 06-05-2010, 06:27 AM   #12
It wasn't the relay. It may be possible that one of the pump powere wires came loose at the pump. Could this cause the relay to buzz since it has nothing to operate?
Old 06-05-2010, 09:06 AM   #13
I don't see how.
The relay may buzz because of a loose turn in the relay coil winding.
Old 06-05-2010, 10:20 AM   #14
Rewards Points: 130
Originally Posted by Yoyizit View Post
I don't see how.
In a normal world and a real world we just call that a BAD relay.
Loose turn in the coil winding.....????
Old 06-05-2010, 11:07 AM   #15
I have to give you credit for not playing
http://www.google.com/search?client=...UTF-8&oe=UTF-8
like that other guy.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 05:39 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Irrigation pump relay RHR Electrical 5 08-23-2009 12:16 AM
Irrigation pump relay rdy2go Electrical 2 06-01-2009 09:42 PM
