Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 12:06 PM   #1
Unhappy
pump
i change the control for a pump 3ph 208 found that the old controler was burn on one ph after installing the new one it started to smoke could the pump have a shorted that cause the old control to trip the breaker n burn the controler when in auto it starts then cut out n also in the hand position
eric greene is offline   Reply With Quote
Old 10-25-2010, 12:19 PM   #2
Electrical Contractor
kbsparky's Avatar
Once the smoke gets out, the equipment is no good ....
-KB
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 05:15 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
