Pulll Sting Light - Box Fill - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 12:21 PM   #1
Does a pull string light mounted to an octogon j-box count any towards box fill?
I've got 2 12awg coming in, 2 12awg going out, 1 for grounds and no clamps. Trying to determine if the light mounted counts as 2 for a device strap.
If it does I need a 2 1/8" deep box, if not I can use the 1 1/2" deep.
Atskodinski is offline   Reply With Quote
Old 03-18-2011, 12:52 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
No, it doesn't count.
Old 03-18-2011, 12:54 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I don't count it. It's not the same as a device on a yoke, as it doesn't sit inside the box.
Kyle
Old 03-18-2011, 01:00 PM   #4
Licensed electrician
Rewards Points: 1,634
Is this two 12-2 in and two 12-2 out plus the fixture or is it 12-2 in and 12-2 out?
Old 03-18-2011, 01:57 PM   #5
It is one 12-2 in plus one 12-2 out plus the fixture.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Several Light Switches Don't Work? Help? Scorpion6 Electrical 4 10-10-2010 09:11 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
