Old 05-15-2005, 12:28 PM   #1
pulling wire through old flexible conduit
Hello, I have an older house that needs to be rewired. The existing wire is run through metal flexible conduit. I am trying to find out if it is do-able to pull new wire through the existing conduit. Any help would be greatly appreciated, thanks.
cbray is offline   Reply With Quote
Old 05-20-2005, 04:55 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You should be able to pull new wiring through the old conduit from box to box. You can use the old wire to pull it with or use an electrician's snake. Bend a hook in the end of one wire of each, connect the hooks, tape them together and pull them through.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 09:35 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Basement Electrical- Flexible Conduit? H Thomas Electrical 2 04-20-2006 09:42 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
