Pulling Power From A Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 12:10 PM   #1
Rewards Points: 552
Pulling power from a switch?
I'm getting ready to install an Aprilaire 700 whole house humidifier with a powered fan. The fan requires a 120V outlet. Unfortunately, there are none near where the humidifier mounts on the furnace.
Can I simply pull power from a nearby switch or is that a code violation? Also, depending on how the switch is wired this may not even be possible. How can I tell if it is?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 12-10-2010, 12:21 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, you would have to have the neutral available. Depending on how the house is wired, that may or may not be the case. About the only thing you can do is open the switch box to see how many wires you have and figure out if the neutral is there or not.
Old 12-10-2010, 12:52 PM   #3
joed's Avatar
Rewards Points: 11,508
If the switch only has a black and white wire and they are both connected to the switch then you can't do it. If there are two or more white wires connected together in the back of the box then you should be able to do it.
Old 12-10-2010, 12:56 PM   #4
Master Electrician
Rewards Points: 3,678
WHy not use the power provided at the furnace?
brric is offline   Reply With Quote
Old 12-10-2010, 01:05 PM   #5
Rewards Points: 552
Because the Aprilaire 700 has a separate 3-prong power cord for the fan that requires a 120V outlet.
Old 12-10-2010, 01:05 PM   #6
Rewards Points: 552
What if it's a 3-way switch? Sorry to complicate matters.
Old 12-10-2010, 01:18 PM   #7
Master Electrician
Install a receptacle from the incoming furnace circuit.
Old 12-10-2010, 01:24 PM   #8
Rewards Points: 552
That's a good idea.
So where should I mount the outlet? Inside the enclosed furnace electrical connections compartment or on the outside of the furnace itself?
Old 12-10-2010, 02:06 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Outside the furnance.
Old 12-10-2010, 02:11 PM   #10
Rewards Points: 552
BTW, I just created an Aprilaire 700 install thread here: Aprilaire 700A on Goodman Furnace?
Please feel free to post any advice you have. I'm sure I can use it.
Old 12-10-2010, 02:20 PM   #11
Master Electrician
From the photos on your other thread you could probably replace the furnace switch with a combo switch/receptacle if the 700 cord is long enough. Don't know about state or local codes governing the red furnace switch plate.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
No power to light switch dayanadan Electrical 3 12-04-2010 03:29 PM
3 way switch controls the power in the other room also? kopac07 Electrical 6 10-17-2009 07:57 PM
power from outlet to switch lincoln85 Electrical 2 10-09-2008 01:04 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 06:45 PM
