Pulling Large Gauge Wires Through Conduit Bodies And Conduit Around Garage Door. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 12:46 AM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If you exit the building wall high above grade and run conduit down the outside wall to your trench a sweep will not work unless you use standoffs.
Is your plan to come down the outside wall ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-02-2012, 01:29 AM   #32
Rewards Points: 3,256
Originally Posted by rrolleston View Post
Can someone show me an example using a conduit sweep to exit a building looks like they will be really hard to use in tight areas.
The pic I posted of sweeps are larger than you will be using, 3" conduit, 36" radius. The point that everyone is trying to make is to use gentle turns as it will be very difficult pulling large wire.
zappa is offline   Reply With Quote
Old 02-02-2012, 07:23 AM   #33
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I understand what everyone is trying to say but even a 24" radius coming out of my building would look terrible and be a trip hazard.
I exit the building with conduit and would have to sweep down 2 feet away from the garage before I can put in my expansion coupling.
My big concern is I have a walkway going between the home and garage. Not much room to work with. Only about three feet.
Would really like to exit the garage as close to grade level as I can and still be able to use my expansion coupling. Making it look a lot better. Trying to please the wife too and she will be helping.
rrolleston is offline   Reply With Quote
Old 02-02-2012, 07:38 AM   #34
Rewards Points: 506
Originally Posted by jasin
I did not see that. My apologies.
I did that AFTER your surprised response. No apology needed.
jlmran is offline   Reply With Quote
Old 02-02-2012, 08:01 AM   #35
Well, to avoid any confusion, a 24" radius sweep would be buried a little less than 24" deep so it would look like a piece of pipe coming out of the ground right up against the building.
Old 02-02-2012, 08:01 AM   #36
Ok. Cool
jasin is offline   Reply With Quote
Old 02-02-2012, 08:13 AM   #37
rrolleston's Avatar
Problem is getting inside the building cleanly. I can use those just about everywhere but not any way to use them to get into the garage I only have about a foot before the garage door after entering the garage.
Old 02-03-2012, 10:51 PM   #38
While on the subject of pulling 3 or 4 large service wires thru conduit, How tough is it to finalize the pull/push of the wire through an LB style fitting. . ( .so you can get the cover on .
Sammy 2 is offline   Reply With Quote
Old 02-04-2012, 02:51 AM   #39
rrolleston's Avatar
With 4/0-4/0-2/0-#2. I am not sure that is even possible.
I have heard of some pulling the wire through the conduit body. Not sure if that is allowed even though people get away with it.
Old 02-04-2012, 11:51 AM   #40
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Sounds like a good way to skin some wires to me
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-04-2012, 12:03 PM   #41
rrolleston's Avatar
Yeah I am leaning more towards large junction boxes where the wire goes into both buildings.
Old 02-04-2012, 08:11 PM   #42
UAW SKILLED TRADES
Stubbie's Avatar
I your plan to come out the top of your panel sweep 90 over the garage door then sweep 90 down the the inside wall then turn 90 out the wall above grade then sweep 90 down into the trench then sweep 90 horizontal at the bottom of the trench? Sorta like this...
Pulling large gauge wires through conduit bodies and conduit around garage door.-garage-conduit-1.jpg
Stubbie
Old 02-04-2012, 08:28 PM   #43
plummen's Avatar
Im thinking those bottem 2 sweeps going out bottem of garage are going to be a joy!
Old 02-04-2012, 09:18 PM   #44
rrolleston's Avatar
That was my plan but I was digging the trench today and looking at it and think it will be easier to continue over the garage door right outside of the garage then down eliminating two 90s.
The Following User Says Thank You to rrolleston For This Useful Post:
plummen (02-04-2012)
Old 02-04-2012, 09:26 PM   #45
UAW SKILLED TRADES
Stubbie's Avatar
I was hoping you would say that ... so you are changing to this
Pulling large gauge wires through conduit bodies and conduit around garage door.-garage-conduit-run.jpg
Stubbie
