Pulling Hot Off Three Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 09:20 PM   #1
Pulling hot off three way switch
This forum has been really helpful, so here I am with (I hope) my last electric question or two for this project. Thanks in advance!
I just wired in a set of recessed cans, and I plan to jump a hot line off a three way switch. It is the second in the series, so power feeds the switch ahead of it and the lights it controls come off it. This means there is a neutral in the box to work with, but I'm not sure which, if any, of the switch terminals is always hot so I can attach a jumper to it. Easy formula (common terminal?) or more complicated? Or, worst case, do I need to pull an entirely different feed for these?
Also, in the series of lights, I connected jumpers to all three wires at each unit, but I'm thinking I probably didn't need to do so with the ground. Not that it's a problem, but I may have wasted a wire nut per fixture.
Cheers!
thewoodguy is offline   Reply With Quote
Old 12-06-2010, 06:16 AM   #2
Licensed electrician
Rewards Points: 1,778
You will need to find another feed. The hot will alternate between the traveler terminals so you do not have a constant hot.
Old 12-06-2010, 07:34 AM   #3
joed's Avatar
Rewards Points: 13,344
You only have switched hot.
Old 12-06-2010, 08:31 PM   #4
Yeah, that's what I figgered. Luckily there was a receptacle near the first light in the series which was on a circuit with room to grow. A little bit of fishing and I was good to go, everything works like a charm.
One of these days I'll unpack my textbook from my residential electricity class and be able to solve these things myself! Appreciate the input!
Tags
3 way switch , grounding
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
