Pulling Conductors Through Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 07:11 PM   #1
DIY
Rewards Points: 150
Pulling conductors through conduit
Just trying to get a feel for what I'm in for...
I am ready to pull conductors into my conduit out to the new detached garage. The conduit is 1.5" PVC, about 72' total length between J-boxes, with 360* total bends. I'm pulling three #2 AWG CU conductors, and a #6 CU insulated ground. It is all THHN/THWN-2 insulation.
1) Is it better to pull one at a time, or all four at once?
2) Am I going to get this done by hand, or should I get busy tracking down a winch?
gp_wa is offline   Reply With Quote
Old 01-06-2009, 07:21 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Pull all at the same time. Whatever you're using to pull (fish tape, rope, etc) Strip the ends and put a few strands of each conductor through your loop. Tape it tight but don't make a big head. This shouldn't be too bad of a pull, just make sure you have someone feeding as well as pulling in sync. Wire lube wouldn't be a bad idea.
wirenut1110 is offline   Reply With Quote
Old 01-06-2009, 07:23 PM   #3
dSilanskas's Avatar
Wicked simple just lay out all the wires nice and straight. Get some wire lube and before you start the pull put alot of lube in the pipe and relube every 20 feet. You can do it by hand just dont cross the wires when pulling them it will make things harder
dSilanskas is offline   Reply With Quote
Old 01-06-2009, 07:32 PM   #4
DIY
Rewards Points: 150
Awesome, thanks guys
Old 01-06-2009, 07:32 PM   #5
Just a thiought Not sure if this helps but when I pull multiples, short distances I stagger the end so I have a tapered start with a pointed tip. 72 ' WOW .... use the lube you don't want to back up and try again.
Chemist1961 is offline   Reply With Quote
Old 01-06-2009, 07:34 PM   #6
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Did you get Simpull wire?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-06-2009, 08:20 PM   #7
DIY
Rewards Points: 150
No. but I has lube
Old 01-06-2009, 11:26 PM   #8
Sounds like plenty big enough pipe, shouldn't go too bad. I'd vac a line in with a wet/dry vac. PVC underground quite often gets water and dirt in it. Also, pushing a snake through can be a pain sometimes. Unless you had the forethought to run the pipe with the bell ends going towards the end of the pipe that you intended to push the snake from. If you used plastic 90's underground, pull slow and have someone feed the wire. Generally, it's a good idea to use metal 90's underground. What happens is the pull string/snake/wire/rope can burn through the 90. Also using a larger size pull rope/string will help to prevent this.
Sparky8370 is offline   Reply With Quote
Old 01-07-2009, 11:22 AM   #9
Rewards Points: 204
Like Sparky said make sure you have someone to feed while some else pulls. The guy feeding is the MOST IMPORTANT one. He can bring the pull to a complete stop and not even know he did it. Both the feeder and puller must be on the same page. You will see!!!
Old 01-07-2009, 01:34 PM   #10
1. Areodynamic/stealthy head
2. Wire lube.
Strip the ends about 12". Unwrap and cut off all but a few strands on each wire. Slip the ends thru the fish tape and fold them back so they end up just short of where you stripped them. Don't overlap them onto the insulated part. Don't twist them individually. Put all four on, fold them back, squeeze them tight with pliers and tape it up, pulling the tape tightly. Your head should end up no bigger than the wire bundle.
The most important role is the guy feeding the wire. He will determine how easy/hard it will be.
220/221 is offline   Reply With Quote
Old 01-10-2009, 07:51 PM   #11
DIY
Rewards Points: 150
We got it done. It was a pretty tough pull and neither of us is interested in doing it again, but it's in there. Thanks for the help guys
Direct burial vs. conduit? vsheetz Electrical 15 01-05-2009 06:39 PM
#3 AWG Copper SER / PVC Conduit Question djejay75 Electrical 4 12-11-2008 11:40 PM
Conduit for #6 wire joey b Electrical 13 11-22-2008 12:13 PM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 03:55 PM
