Old 11-06-2009, 02:31 PM   #1
Default Pulling 120V outlet from a 240V circuit?
I'm hoping for some advice. I recently installed a built in oven with a gas drop in range on top of it. The oven is 240v requiring a 30 amp circuit (hard wired in a junction box) and the range is 120v needing a 15 amp circuit (it has a grounded plug). I'm planning on running a new circuit for the oven using 10-3 NM with a 30 amp double breaker and install an old work box in the wall to wire it. Now my question, Can I just run a some 10-2 nm from 1 hot wire, the neutral and ground from the 240 line up to a second old work box for the outlet or do I need to run a new circuit for the 120v outlet? All this work will be done in an adjacent cabinet
And a follow up, will there be any issue using a 15 or 20 amp duplex plug (for the range) on the circuit? Should I install a 120v 30amp outlet and use an adapter to go from the 30amp outlet to the 15amp plug
npage148 is offline   Reply With Quote
Old 11-06-2009, 02:35 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
You can't piggyback a 120v circuit off of a 240v circuit
You need to run a seperate 120v circuit
And you can't put a 15a or a 20a outlet on a 30a circuit
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 11-06-2009, 04:37 PM   #3
Thumbs up
Additionally. There is no 30A. Single pole breaker to be had. (For the same reason) (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-06-2009, 05:10 PM   #4
???? http://www.relectric.com/Store/Circu...QH130?kty=6361
LanterDan is offline   Reply With Quote
Old 11-06-2009, 05:24 PM   #5
300zx's Avatar
Post
Originally Posted by LanterDan View Post
yes i have also seen a few different brands also Cuttler Hammer http://electrical.hardwarestore.com/...r--658734.aspx every brand i think makes them http://www.google.com/products?hl=en...ed=0CBsQrQQwAw
300zx is online now   Reply With Quote
Old 11-06-2009, 05:59 PM   #6
Electrical Contractor
You are just not looking in the right place.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-06-2009, 06:18 PM   #7
My License Ain't 4 Sale..
You could set a four circuit panel under the cabinet and feed the oven with a 30 A double pole, and the 120 V recept from a 20 A single. But if you are already running the 10-3, might as well run a 14-2 and be done with it.
Old 11-06-2009, 07:38 PM   #8
No
You don't need a new circuit. You can tap off the countertop receptacle circuit if it is easier. It may be easier just to run a 12/2 20 amp circuit for the cooktop recep. You have to make that decision.
You could set a four circuit panel under the cabinet ....
Uhhh....it would have to be a big assed cabinet to get the required clearances
220/221 is offline   Reply With Quote
Old 11-07-2009, 08:03 PM   #9
Thumbs up
Thank you for providing the link. So far, I haven't come across the need for that breaker. They (30A. breakers) are mostly used in Shop compressors and Medium sized A/C units. And those run on 208/240V. Thankx again! (No matter what)Don't Drink and Drive, Ever!!!
Old 11-08-2009, 08:55 AM   #10
kbsparky's Avatar
Thank you for providing the link. So far, I haven't come across the need for that breaker. They (30A. breakers) are mostly used in Shop compressors and Medium sized A/C units. ....
A legitimate use for a single pole 30 Amp breaker is an RV outlet. Many campers have the NEMA TT-30 plug attached for such a circuit.
-KB
Old 11-08-2009, 12:59 PM   #11
Thumbs up
KB Sparky (Poster #10) Thank you for ENLIGHTening me. BTW I DO eat Dessert First (sometimes)! Eliminate confusion Through Education; Don't Drink and Drive, Ever!!!
Old 11-08-2009, 01:04 PM   #12
Red face
You are (probably) right! BTW. I didn't say it doesn't exist. Just that I haven't had a need or request for it!! No matter what) Don't Drink and Drive, Ever!!!
Old 11-08-2009, 01:29 PM   #13
300zx's Avatar
Post
quoted
More On This Topic
Hi! This is Jon from expertvillage.com. In this video clip, I will be talking about the electrical requirements for a metal shear. On our foot operated metal sheer, it is wired for 220. We have our on/off switch here and that wire runs into this junction... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I will be talking about electrical safety. This particular sanding machine is 220 volts meaning it requires a lot more voltage than your typical outlet that you would have in your house... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. One choice you need to make when you are planning is whether you are going... Read More »
The majority of televisions in homes today are built around the cathode ray tube. With plasma televisions, the central element is the plasma in a fluorescent light made up of electrically charged ions and electrons that are free flowing and gaseous. The... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you Part 6 of replacing an old electrical outlet. Next we are going to install a new plate to match our outlet. After that go ahead and turn the power back on. To test... Read More »
Obtain 120V 30 amp from 120/240 30 amp generator outlet rick p Electrical 2 08-30-2009 02:06 PM
120v for shed from 240v HotTub circuit? MrMark Electrical 6 04-06-2009 02:43 AM
30a 240v air compressor circuit crecore Electrical 2 09-21-2006 09:52 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 10:38 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 10:45 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
