Pulling A 12/2 Run From 12/3, How To? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 08:16 PM   #16
liscenced electrician
Rewards Points: 538
Originally Posted by gregzoll View Post
What in the world are you talking about. Getting clarity from the person that starts the thread, instead of having to play guessing games, makes stuff easier to solve, and plus makes the thread no longer than three maybe four posts.
In some circumstances, but not this one. A pretty simple, straight forward question was asked and it took a full page to get a clear answer. Seems to be a common occurrence, ignore the original question and go off on some tangent
jimmy21 is offline   Reply With Quote
Old 10-23-2011, 08:19 PM   #17
Rewards Points: 6,652
A lot is because some of us like to have fun when you get a new person and want to try to work through their situation, not just rush to end the topic. The problem with the starter on this thread, is that the OP was not clear in what they were attempting.
Old 10-23-2011, 08:49 PM   #18
Rewards Points: 538
where as i prefer to first answer their question and THEN add additional information.
I've noticed it on many forums. If too much information is given, people will ignore your questions. If you ask a bunch of questions people will only answer the easiest most obvious question
Old 10-23-2011, 09:05 PM   #19
Rewards Points: 197
So that I can understand this better, I assume... we're talking about nm cable right, and nothing being run through flex? And it sounds like... there are two hots, a neutral and a ground in it, unless I am missing something. What I think some of us suggested is just disconnect one of the hots, from both ends, so you just have one dead wire there in case you ever want a new line someplace.. as opposed to cutting it off or short and being forced to run a new line.. and in essence, you save yourself all the hassle of running a new line, stapling the cables to joists, ignoring the ones that are in-between the studs, etc... (I'm just saying... I'm still recovering from spending the last week in an attic re-running lighting through a unit, and man does it get tiring at times in close quarters where all you can do is roll over.., so if it's safe, effective, and plans for the future and takes less work, yes!!!!)
:insert cricket chirpings:
...is this correct? If the case is that, then he (or she..) doesn't need to run a NEW line, and by disconnecting (not cutting) the spare extra wire at each end, he effectively is creating a 12/2 line which he can use and just not even worry about the third line until the time comes when a potential new line is desired..
scyarch is offline   Reply With Quote
Old 10-23-2011, 09:05 PM   #20
I=E/R
a7ecorsair's Avatar
Originally Posted by SocalPaddy View Post
Obviously something getting lost in translation here. My ultimate aim is a 12/2 run for an outlet I need in the attic.
*I have a run of 12/3 from the breaker box which WAS wired to a now defunct 3-way switch in our kitchen.This 12/3 is currently is currently attached at the breaker box. The other end is now in a junction box in my attic and the ends are capped and the breaker is off.
*The 12/2 I need is near that location.
*I understand from this thread that i can pull a 12/2 by taking it from the 12/3 at this junction box in my attic.
*The remaining wire (red) may be capped in this junction box for possible future use.
*The other end of the red at the breaker box may be left alone
Lost in translation?
Before you get carried away, a 12/3 running from the breaker box to a switch box has nothing to do with a three way switch. Are you sure that isn't a MWBC? Where do the black and red wires connect inside the breaker box?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
gregzoll (10-23-2011)
Old 10-23-2011, 09:10 PM   #21
Jimmy, here too much just either makes it harder to decipher if they do not place the info into paragraphs, or sub brief, then spell out each instance. I would rather have the info in the following order:
1. What are they seeing on their end.
2. What have they done if anything in attempting to fix the problem.
3. If not able to fix, what in what order are they asking for help.
4. And in the end, what solution are they looking for, instead of abandoning it in the end, while everyone else is trying to play poker with the original post, to see who has the five card Monty.
Old 10-23-2011, 09:24 PM   #22
Rewards Points: 538
It doesn't really matter what the cable was used for but i think what a7ecorsair is getting at is........ are you absolutely sure the cable doesn't go to any other box first?
The Following User Says Thank You to jimmy21 For This Useful Post:
scyarch (10-24-2011)
Old 10-24-2011, 12:52 AM   #23
Rewards Points: 197
I didn't even think of that and that kind of thing happens to me routinely. Strange wiring jobs from anytime someplace is wired...
That said... was I incorrect that the red can't just be disconnected, and use the white and black to power the switch and light?
Old 10-24-2011, 01:15 AM   #24
Rewards Points: 538
If it goes somewhere else, it really depends on what else is on the circuit
Replacing 12/2 with 12/3 behind wall iya Electrical 8 06-20-2010 07:51 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Afci & 12/2 golddog Electrical 11 12-10-2009 11:23 AM
12/2 vs. 12/3 Suncrest79 Electrical 2 03-07-2009 02:42 PM
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
