Pull Old Wires Through 120' Foot Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 09:36 AM   #16
Originally Posted by bobelectric View Post
You must abandon the old feed and run a new conduit system to comply with current codes, liability issues you know.
Is this definitely true? Is it the smartest thing to do anyway? I've got a 2 year old so I lean more towards the safest options these days....
matt55 is offline   Reply With Quote
Old 07-13-2012, 09:38 AM   #17
I'm gonna try to pull the wires today, not sure if I want to invest in pullers etc given the possibility it won't work. Any tips on making it pull easier? I may just give it a token try then go try to rent a trencher......
Old 07-13-2012, 10:23 AM   #18
Master Electrician
Hook a back rope on to pull the new stuff in. If you have space you can half hitch a rope on the side your trying to pull them out from to give you more line and perhaps a second person to help pull. They should come out. When you go to pull the new ones in put some wire lube on them to make life easier.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 11:14 AM   #19
Rewards Points: 826
Well since it is conduit the whole way then why not use the old wire to pull through the new wire and save a step? Ditto on the wire pulling lube. It is cheap and works incredibly well..
curiousB is offline   Reply With Quote
Old 07-13-2012, 12:19 PM   #20
Master Electrician
Because if the old ones are tough to get out by themselves pulling in the new at the same time will only make it harder. Plus you cant feed them as you'll just jam the nose.
Old 07-13-2012, 01:54 PM   #21
There is a big risk the old wires are "welded" in at some points, which even if I could break, may leave sharp points which could damage new wire. Also, i'm not 100% sure these isn't some break in the line somewhere I haven't dug up yet, and its got an awkward angle at the end. So rather than investing in a puller, etc., and a days worth of effort pulling for something that may or may not be worth it (maybe 50/50 shot?). I'm gonna go with a sure thing and rent a trencher for a day and put in the new line. I'll feel a bit better about it knowing everything is complete and clean, even if it costs a couple extra bucks.
Old 07-13-2012, 03:19 PM   #22
Master Electrician
smart, more should be like you
Old 07-13-2012, 03:27 PM   #23
Andrew, you might know...any risk using PVC to replace the old EMT? for about 20 feet the pipe will run right next to the KoolDeck about 2 feet from the water. Its probably fine and i'm just being paranoid, but there wouldnt' be any electrical risk that close to the water with the PVC is there? at least not anymore than I had with the metal conduit.....
Old 07-14-2012, 12:17 AM   #24
Rewards Points: 508
Send a message via AIM to theatretch85
If you're going to run new, I'd suggest you try and pull out the old wires anyway, recycle that scrap wire and at least get some money for it. If it breaks, just pull out whatever you can, 120' is a decent length and if you can get all the conductors out you could offset the cost of installing the new stuff.
theatretch85 is offline   Reply With Quote
Old 07-14-2012, 04:28 PM   #25
Rewards Points: 826
OK your call. Its odd though if you are willing to just dig a 120' trench, install new conduit, back fill, clean up and landscape (in 115 degree weather) why you wouldn't at least trying pulling one of the wires from the old conduit first. Doesn't seem much downside giving it a go. If it won't budge, oh well, start digging.
Wire in conduit trekketoo Electrical 19 04-24-2012 05:38 PM
Secure Wires from Conduit in Sub Panel brgmgb Electrical 7 09-29-2011 09:10 PM
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 11:23 AM
Wire passing through a J-box in a Conduit run theatretch85 Electrical 4 05-22-2010 03:56 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
