-   -   Pull elbow behind drywall? (http://www.diychatroom.com/f18/pull-elbow-behind-drywall-105846/)
WillK 05-28-2011 11:40 AM
I know junction boxes must be accessible... does this apply to pull elbows in conduit?
I need to run from a junction box at the floor to my service panel, but the junction box is too offset for a straight run and too close to use long radius elbows... This is a 1-1/4" conduit run. A pull elbow would work just right, but it is in an area that would be enclosed...
Unless it is counted as being accessible if I use a panel which can be unscrewed for covering it?
At this point I guess I'm asking because I'm curious but I'm going to go up in size to 1-1/2" PVC so I can use a straight tube I already have and get the elbows with funds from returning the EMT pipe and fittings. Funds are cut off so buying more EMT is out.
Techy 05-28-2011 11:43 AM
access panel would be required
rjniles 05-28-2011 12:34 PM
Was at Home Depot the other day and they have a plastic access panel that is about 4" by 6", perfect for you application. They were at the water heater accessory area.
