Pull Cord Light Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2008, 09:12 AM   #1
Pull cord light question
Ok, I put a pull string light in my garage attic and it's at the end of the circuit. The box is plastic and the pull string light fixture didn't have a ground screw. So, is the ground wire just floating in the mounting box since there is nothing to attach it to? Thanks.
737Pilot is offline   Reply With Quote
Old 12-20-2008, 09:15 AM   #2
DIYer
Fold it back out of the way.
Gigs is offline   Reply With Quote
Old 12-20-2008, 09:38 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
There's no metal in contact with human touch if energized in case of a fault with these type fixtures and a plastic box .... so UL doesn't require a grounding means on them. Just don't stick your finger in the light socket...
Old 12-20-2008, 12:27 PM   #4
Thanks guys, that's what I figured, but wanted to ask the pros. I learn a lot from you all, thanks again!!
Old 12-20-2008, 06:11 PM   #5
Rewards Points: 900
Some "electricians", and I use that term very loosely here<g> would cut off the ground wire if it's not required in that box with that fixture. Of course this is not the correct (or permitted) method, since next month you may decide to extend the circuit from that box, and you need to have the ground wire to pigtail to the next fixture.
Ultrarunner2017 is offline   Reply With Quote
Old 12-21-2008, 09:49 AM   #6
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
So in said situation, does the code require the ground wire be left in the box? What if Romex without ground is run to said light fixtures? Do you know where the code mentions this, is it the 6" of wire in each box that applies?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
Halogen recessed light question tripower Electrical 14 10-12-2008 09:34 PM
Electrical Question - adding a 3 way switch to existing Light Marcus23 Electrical 5 10-11-2008 08:52 AM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
