-   -   Pull cord light question (http://www.diychatroom.com/f18/pull-cord-light-question-34094/)
737Pilot 12-20-2008 09:12 AM
Ok, I put a pull string light in my garage attic and it's at the end of the circuit. The box is plastic and the pull string light fixture didn't have a ground screw. So, is the ground wire just floating in the mounting box since there is nothing to attach it to? Thanks.
Gigs 12-20-2008 09:15 AM
Fold it back out of the way.
Stubbie 12-20-2008 09:38 AM
There's no metal in contact with human touch if energized in case of a fault with these type fixtures and a plastic box .... so UL doesn't require a grounding means on them. Just don't stick your finger in the light socket...:)
737Pilot 12-20-2008 12:27 PM
Thanks guys, that's what I figured, but wanted to ask the pros. I learn a lot from you all, thanks again!!
Ultrarunner2017 12-20-2008 06:11 PM
Some "electricians", and I use that term very loosely here<g> would cut off the ground wire if it's not required in that box with that fixture. Of course this is not the correct (or permitted) method, since next month you may decide to extend the circuit from that box, and you need to have the ground wire to pigtail to the next fixture.
jamiedolan 12-21-2008 09:49 AM
So in said situation, does the code require the ground wire be left in the box? What if Romex without ground is run to said light fixtures? Do you know where the code mentions this, is it the 6" of wire in each box that applies?
Jamie
