Pull Chain Switch Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 03:48 PM   #1
rgm
Pull chain switch installation
I currently have a flush mount ceiling light that has two sockets with bulbs in it. It is currently wired to a wall switch (which I will leave in place as it runs another light at the other end of the ceiling).
I need the ability to be able to turn off this light only and would like to instal a pull chain switch. The wiring is two black and ywo white coming from the sockets attached to one black power wire and one white wire. The ground is also connected. Both bulbs are 60 w max.
What kind of switch do I need to operate both bulbs and how is it wired into the light fixture. I assume the one black power wire connects to one of the pull chain switch wires and then the two socket wires connect to the other switch black wire, connecting the power circuit thru the switch.......
Please let me know if this is correct or not or if it can even be done.
RGM
rgm is offline   Reply With Quote
Old 09-05-2008, 11:30 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by rgm View Post
...I assume the one black power wire connects to one of the pull chain switch wires and then the two socket wires connect to the other switch black wire, connecting the power circuit thru the switch.......
RGM
***** I don't like to advise that people make modifications to electrical devices or equipment outside of manufacturers recommendations. *****
This would be correct. You switch the 'hot' wire. The switch would have to have a minimum rating for the circuit it is being connected to. In your scenario, it's rating would have to be at least 125V-5A I believe.
I would consider looking into a new fixture that already has a pull switch...maybe a ceiling fan/light combo.
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
New Switch Installation Question-Grounding brejohns Electrical 1 01-08-2008 05:42 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
pull chain switch bobo Electrical 2 12-28-2005 05:16 PM
