Old 11-29-2005, 04:18 AM   #1
Question
pull chain switch
hi,
i just replaced a pull chain switch for the lights on a ceiling fan. it has 5 60 watt lamps, so 300 watts, i installed a 6a@125vac switch, which should be good, cause 300 watts will draw 2.5amps. but the switch was labeled 3a 125vl/6a 125vac, 3a 250vac. what is "vl"
thanks,
bob
bobo is offline   Reply With Quote
Old 12-03-2005, 08:34 PM   #2
World famous jerk.
pull chain switch
You may remember from high school that "L" is the symbol for inductance.
"VL" stands for Volts, Inductive. Examples of inductive loads include motors, solenoids, and relays. Inductive loads exhibit inrush of current, when energized, that can be many times the regular current draw. Also, when de-energized, the magnetic field collapses, generating a high voltage transient. This transient can cause arcing across mechanical switching contacts or can cause damage to solid-state contacts. For this reason, swtiches either have a "VL" rating or a "horsepower" rating that is much less than their rating when used on other load types, such as your incandescent lamps. Everything you thought you knew about sizing switches goes out the window when sizing a switch for inductive loads; particularly motors.
mdshunk is offline   Reply With Quote
Old 12-28-2005, 06:16 PM   #3
Question
pull chain switch
this switch is ONLY controlling the lights of the ceiling fan, motor is on a 3 position pull switch of its own. so the 6a/125vac switch should be ok, for just the lights, right?
bob
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
