Pull Chain - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 07:09 PM   #1
pull chain
Dang it ! I pulled on the chain to slow down the ceiling fan, just in time for a cold front to pass through, but it broke off. Its less than 2 years old.
Only the light can be controlled by the wall switch. Even if I wanted to cut the power to that room (which I don't because the little darlings watch tv in there and I don't want them muscling their way into the living room, there is no dedicated breaker for only that room.
Is this thing fixable? I don't mind killing the hydro to the whole house to work on it, but before I take it apart I need to know if its worth my time.
Thanks in advance,
creeper is offline   Reply With Quote
Old 06-02-2013, 07:23 PM   #2
Rewards Points: 12,878
It's about a $3.00 or less fix. Any hardware, or box store will have it.
Old 06-02-2013, 07:26 PM   #3
Joe Thx pal for the input, but I did keep the chain that stayed in my hand. So I guess I know the answer..kill the power and try and take the thing apart. No other way around it
Old 06-02-2013, 08:52 PM   #4
DIY staff
Rewards Points: 7,174
Try this---no need to junk the fan---
Take off the light shade---you will see three small screws that hold light cap onto the can like part with the broken switch---
When that is loose--unplug the light from the fan---there is a square plug--they can be a trick to unplug---then look up into the can.
You will see the switch---to remove it---turn off the power to the fan--then unscrew the cap on the outside that the chain used to go through.
Pull out the switch---carefully cut the wires if you can't undo the wire nuts(usually they are a crimped on thing that can't be unscrewed)
Buy a new switch---Home Depot lighting department---get two small wire nuts,too----replace the switch---
The old one is glued together and can't be fixed----
If you have trouble----post a picture of the insides of the unit---Mike---
creeper (06-02-2013)
Old 06-02-2013, 09:22 PM   #5
I will do as you advise when I get a chance. But for now I guess the blasted thing whirls around at full speed. Its throwing off a bit of a chilly breeze which is currently not welcomed
Old 06-02-2013, 09:47 PM   #6
DIY staff
Broke in the on position----what a drag-----you could kill it by removing the switch---and wire nutting the two wires.
Old 06-02-2013, 10:29 PM   #7
There is no visible switch, so I will take the cover off as you suggest and then post a photo for further instructions.
Just my luck that its cold out
Old 06-02-2013, 11:20 PM   #8
Rewards Points: 1,192
Reverse fan rotation until you can take it apart.
bobelectric is offline   Reply With Quote
Old 06-03-2013, 11:00 AM   #9
You can see the chain in this little plastic box. Cant seem to pry the black bottom off. Should it even come off
Old 06-03-2013, 11:10 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 850
Allow me to think out of the box....put a speed control on the wall?
ddawg16 is online now   Reply With Quote
Old 06-03-2013, 11:20 AM   #11
sorry not happening today
Old 06-03-2013, 11:23 AM   #12
Off came the black lid..on went the chain..put it all back together..nothings changed...what am I missing
Old 06-03-2013, 11:49 AM   #13
Electrical Contractor
jbfan's Avatar
Rewards Points: 150
Do you mean it is still running on high?
Those switches were never meant to be repaired.
$5 at home depot for a replacement.
Old 06-03-2013, 04:10 PM   #14
Joe It was 4.99.
It seems you were right all along, except I didn't know what the heck you meant.
Sometimes you need to place the dots real close in order for me to connect them. It may be best to assume I know nothing and proceed from there.
FIY..peace and harmony have been restored to the family room
Thx
The Following User Says Thank You to creeper For This Useful Post:
oh'mike (06-04-2013)
Starting a Stihl chain saw maddog1 Tools 6 04-05-2013 07:52 AM
old pull chain metal wall mount exhaust fans mssjam Remodeling 3 10-13-2012 05:33 PM
Garage door chain sag Sweet Lew General DIY Discussions 5 12-19-2011 09:48 AM
how to replace pull chain switch on ceiling fan lights carolraine Electrical 1 07-25-2011 07:38 AM
pull chain switch bobo Electrical 2 12-28-2005 06:16 PM
