Old 02-20-2009, 11:55 AM   #1
DIY'er
jamiedolan's Avatar
Pull boxes / elbows accessable?
HI
Ofcourse I know anywhere there is a junction, it must remain accessible.
But what about the factory pull elbows with a cover plate, or a box that is strictly for routing wires with no connections / junctions.
Do these always have to stay fully accessible when no junctions are present? (wires just pass through unbroken) I know it would make it harder to change things later if you could not get to them easily, but it would still be easier than romex in the walls....
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 02-20-2009, 12:08 PM   #2
J. V.'s Avatar
If the enclosure is designed to be opened in any way it must remain accessible.
Old 02-20-2009, 05:11 PM   #3
Electrician
Jamie, look at 314.29
chris75 is offline   Reply With Quote
Old 02-20-2009, 06:18 PM   #4
DIY'er
jamiedolan's Avatar
I suspected that was the case, but could not find the code on it. Thanks for the reference.
Jamie
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Boxes recessed too deep rondo Electrical 10 12-01-2012 07:46 PM
Mounting 3 gangable switch boxes mcvane Electrical 11 01-16-2009 09:43 PM
No Pull lube jamiedolan Electrical 7 12-16-2008 01:00 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
