-   -   Puck lights with touch dimmer (http://www.diychatroom.com/f18/puck-lights-touch-dimmer-123396/)
830ttime 11-14-2011 09:26 AM
I have 5 LV puck lights that came with a touch, 3-level dimmer (which also has an off position). I have the lights plugged into a switched outlet.
Here is the problem. The dimmer's default position is apparently "off". Once I flip the switch to off and and wait more than five seconds before I turn it back on, the lights remain off. If I turn it off and back on very quickly, the lights stay at the last setting.
Can I get a different dimmer (slide type with no "off") to replace the touch dimmer?
830ttime 11-15-2011 10:19 AM
Anyone have a suggestion for this? Any way to defeat the off position on the dimmer?
Colomboj 11-15-2011 10:42 AM
I would guess there is a transformer in this setup somewhere more than likely built into your dimmer. So my guess would be that your stuck with what you have. I could be wrong but I can't really see what you have either.
830ttime 11-15-2011 10:52 AM
The touch pad dimmer plugs into the transformer with a basic slide-on electronic connector. The transformer then has two wires out each end, one runs to the series of lights, the other runs to the outlet.
Colomboj 11-15-2011 01:37 PM
You might be in luck then. If you are dimming at 120v before it goes to the transformer than any 120v dimmer should do the job.
