PSE&G Usage Doubled The Last Two Months - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 05:36 AM   #46
An old Tradesmen
Rewards Points: 6,112
Originally Posted by ZenicaNJ View Post
The Trane air handler is model 4TEE3F31B1000AA.
The thermostat is White Rogers 1F97-1277 Touchscreen Thermostat.
(I'm 99% sure this is the model I have)
That would be the wrong model thermostat to have with a heat pump with aux electric heat. Pull it off its back plate and double check if that is the model number.
Please post the model number of your outdoor unit.
From your breaker description on the air handler, you have 15 KW of electric strip heat. Its possible that you have a short in your low voltage wiring that is causing 5 KW of the strip heat to be on almost all the time.
Old 02-04-2013, 08:28 AM   #47
Originally Posted by frenchelectrican View Post
Here the issue what you have there.,
The thermosast is not compareable with your heat pump.,
Merci,
Marc
You are in fact, correct. When I removed the thermostat last night I did not recognize the model number from the other numbers and it
does not actually use the word "Model:" in front of the number.
I do have 1F95-1277
ZenicaNJ is offline   Reply With Quote
Old 02-04-2013, 08:29 AM   #48
Rewards Points: 1,426
My bills have been significantly higher this Dec/Jan than last year. It's been pretty cold in the north east. Don't know how much that could affect your bill, but the last 2 years were pretty mild compared to this year.
mikegp is offline   Reply With Quote
Old 02-04-2013, 08:31 AM   #49
Trane heat pump model XR14 model number 4TWR4030C1000AA along with Trane air handler model 4TEE3F31B1000AA
Old 02-04-2013, 11:25 AM   #50
Using the link frenchelectrican provided and the model numbers for my equipment, can someone suggest the correct settings so I can verify them in the thermostat?
Old 02-04-2013, 04:39 PM   #51
An old Tradesmen
1-HP 1
2-ele
3-0
4-don't touch
5-sl
6-sl
7-sl
8-cl
9-up to you
10-up to you
11- do you have an outdoor sensor, and is it accurate
12-your choice
13-b
14-ds
21-off
Clarification on cam-lock usage for private residential applications spowell71 Electrical 3 01-29-2013 02:35 AM
Heating gas usage and temperature for comparing yearly usage WillK General DIY Discussions 1 12-19-2011 03:33 PM
help for gas usage Amy28 HVAC 1 04-27-2011 05:39 AM
