Proximity Of Water Supply Pipes With EMT Conduits - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 06:21 PM   #1
Rewards Points: 1,584
Proximity of water supply pipes with EMT conduits
I have a situation where I have three 1/2" EMT conduits that runs vertically down along a concrete block wall.
I also need to make a run of a 1/2" copper pipe for water supplies horizontally across said wall, crossing over the three electrical conduits. I don't need to "loop around" them, I am just crossing over, but it is such that the copper will actually touch the three EMT conduits.
This is a hot water pipe, so the pipe will be warm most of the time.
Will this hot/warm copper pipe be an issue when it's so closed to the electrical conduits?
Should I slide a piece of roofing felt between them?
miamicuse is offline   Reply With Quote
Old 02-08-2013, 06:30 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no distance you have to stay away from, but they cannot touch.
Old 02-08-2013, 06:45 PM   #3
In that case, if I put a heat shrink tubing around the copper pipe, it will work?
Or is it better with a piece of roofing felt?
Old 02-08-2013, 06:47 PM   #4
k_buz's Avatar
If possible, I would insulate the copper water line.
Old 02-08-2013, 07:56 PM   #5
Rewards Points: 192
You can just use some cheap foam pipe insulation. I would be more worried about the disimilar metals touching and corroding more than the electrical grounding issue.
bcgfdc3 is offline   Reply With Quote
Old 02-08-2013, 08:01 PM   #6
I can't use foam insulation, there is really no clearance there. I may be able to pry them apart ever so slightly to slip in a piece of roofing felt but thicker foam insulation will not work in this case.
Old 02-08-2013, 09:07 PM   #7
Idiot Emeritus
Rewards Points: 1,492
This is true.
Around here, if one of the pipes is wrapped with at least two layers of 10 mil tape, it's ok. I doubt if this is based on code, but it's the basic standard that the inspectors use.
If you use roofing felt, it'll need to be secured somehow so that it cannot fall off. The pressure of the pipes pushing on each other is not enough, it needs to be secured.
Rob
micromind is offline   Reply With Quote
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
I hear water running in my pipes 24 hours. Prata Plumbing 22 03-14-2012 08:08 AM
Bonding water pipes WillK Electrical 14 06-14-2011 07:14 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 02:22 AM
