Old 10-26-2011, 09:13 AM   #1
proximity of copper h2o pipe to MC cable
i plan to run some MC cable vertically within an inch or so to the cold water supply pipe going to my bathroom vanity. i was wondering if this is OK or there must be more clearance between the two, for some reason.
thanks
Old 10-26-2011, 09:19 AM   #2
Electrician
SD515's Avatar
No clearance required, but it's better to not let them touch if you can.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
amakarevic (10-26-2011)
Old 10-26-2011, 10:18 AM   #3
i don't know if it is code but in commercial, mc cable is often attached to copper or iron pipes with tyraps
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
Old 10-26-2011, 10:54 PM   #4
Electrician
SD515's Avatar
Does that make it right? Are those copper or iron pipes listed as suitable for support of electrical wiring methods?
Kyle
Old 10-26-2011, 11:22 PM   #5
liscenced electrician
Not on any of the jobs I've ever been on
jimmy21 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimmy21 For This Useful Post:
SD515 (10-26-2011), Speedy Petey (10-27-2011)
Old 10-26-2011, 11:24 PM   #6
Electrician
SD515's Avatar
At least not anything I've installed.
Kyle
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 08:48 AM
Size of hole for 1/2" copper pipe through floor FirstAndTen Plumbing 7 02-02-2011 08:46 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 07:38 PM
