Properly Grounding New Incoming Electrical Service - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 10:46 PM   #1
properly grounding new incoming electrical service
Is it a new law in Kentucky to run the ground wire from the meter to the re-bar in the footer of a double wide house?
Belo is offline   Reply With Quote
Old 12-06-2011, 10:51 PM   #2
Rewards Points: 6,652
You are talking about a Ufer ground. http://en.wikipedia.org/wiki/Ufer_ground It has been around since WWII.
Old 12-07-2011, 04:33 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Kinda but generally for new construction Ouias { yeah } they do ( for the Ufer ) but for exsting location for new service that depending on the AJH or inspector to say.
The double wide which you are refering to the mobile home or modular home? that part will make the differnce on how to deal with the code.
I know couple KY electricians I can talk to them and see what they have to say with their codes. then I can post the answer.
Merci,
Marc
How to properly test grounding system Ultrarunner2017 Electrical 4 02-03-2009 11:59 AM
Bizarre Electrical Problems - Grounding? CaptHanky Electrical 45 06-27-2008 10:18 AM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 08:56 AM
Grounding new service TonyD Electrical 11 08-21-2006 12:03 PM
electrical service to barn bsteven Electrical 1 04-18-2005 09:43 PM
