Old 05-03-2009, 09:54 PM   #1
Default proper wiring of outlets on dock near water
we inherited my granfathers lakehouse and I was there this past weekend and noticed how he ran electricity to the dock. The romex connecting the 2 outlets on the doc was not in any conduit and actually submerged in water under dock (used to be dry ground but lake has risen quite a bit). In one of the outlets there is a ground spike going through water to ground. I flipped the breaker on that circuit until I could determine if it was safe. What is recommended fault protection and set up for wiring around water?
thanks
elcid98 is offline   Reply With Quote
Old 05-03-2009, 10:21 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
What color is the wire?
Grey is rated for outside use - exposure to sunlight
But it should be wired in conduit if there is any chance of physical damage
Is this one circuit?
Protected by GFCI outlet/breaker?
What are the outlets used for?
A ground spike? Going thru the outlet?
Or a ground spike in the water that is wired/grounded to the outlet?
GFCI is 100% required
I would not want a GFCI outlet near the water
So either a GFCI breaker or another outlet further away from the water
Scuba_Dave is online now   Reply With Quote
Old 05-03-2009, 10:25 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Getting an electrician out to survey and then fix this scary mess, that's what.
Old sig removed. Thankfully Advanta is dead.
Old 05-03-2009, 11:25 PM   #4
Yoyizit's Avatar
http://ecmweb.com/ops_maintenance/ho...rocution_case/
Yoyizit is online now   Reply With Quote
Old 05-03-2009, 11:59 PM   #5
Thanks for all the replies. the wire is black wire from receptacle to recetacle. I don't think they are GCFIs the ground if through water to ground (mostly b/c water has risen)
I'm fairly comfortable with electrical work but when it involves water it scares me a bit. Yes, the more I think about this and after reading that article I am definitely going to get a licensed electrician out to look at it. Now we have kids playing around the dock and it is definitely not worth the risk.
Old 05-04-2009, 01:27 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Docks are very much like swimming pools and are not DIY and in some cases are not for all electricians. You need an electrician that is familiar with the requirements for floating docks in your area. This is not DIY or owner stuff get a experienced electrician with floating docks. Here is an example of the requirements for my area........
"Ever wonder what happens if you get scared 1/2 to death twice?" Larry the Cable Guy
Stubbie is online now   Reply With Quote
More On This Topic
How to Use Wire Strippers
How to Use Wire Strippers by Expert Village
Hi! I'm Drew Finch here for Expert Village and we are talking about standard hand tools and how to use them. Now we are going to use a couple of basic tools to help strip some romex wire if you are doing any wiring. The first thing we have to do is get... Read More »
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
How to Ground a Shop Vac
How to Ground a Shop Vac by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip, I'll be talking about grounding instructions. This tool must be grounded. If there is some type of malfunction with the tool, the grounding wire on the tool would allow the electricity to... Read More »
Hi! My name is Eric. On behalf of expertvillage.com, I’m here today to talk to you about the correct way to go through and power your various iPods. First of which we’re going to talk about is the current model iPod shuffle, which features... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 08:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 02:05 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 02:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
