Proper Wiring Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 12:51 PM   #1
Rewards Points: 172
Hello:
I am renovating my bathroom and currently have 1 dedicated 20A circuit running to it. The bathroom and 5'x8'. The plan is to have a 1 GFCI outlet, a vanity light with dedicated switch, 2 overhead lights(1 over shower) and an exhaust fan all on one switch. My first question is it ok to use 2 switches instead of 3? I have attached a wiring diagram based on what I wanted to do. Does everything seem okay with it?
I am using 15A switches only because that is what I have currently. Is it necessary to use 20A switches? The AKDT63W switch is a timer switch.
zephed666 is offline   Reply With Quote
Old 06-25-2012, 01:11 PM   #2
Licensed electrician
Rewards Points: 1,788
Unless the fan is over the shower the lights and fan do not need GFI protection.
You can use only two switches but it limits your ability to leave the fan on to exhaust moisture without also leaving the lights on.
A 15 amp switch is fine.
Nice diagram.
Old 06-25-2012, 01:31 PM   #3
Oso954's Avatar
Rewards Points: 1,338
The AKDT63W is a three position timer switch. It is designed to let you turn the lights off and run the fan for a preset time period.
Oso954 is offline   Reply With Quote
Old 06-25-2012, 01:35 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Not the way the wiring diagram shows it. You would need 2 switched hot leads from that switch.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
DangerMouse (06-25-2012)
Old 06-25-2012, 02:37 PM   #5
Rewards Points: 172
Nice diagram.
One light is over the shower. Doesn't that need to be GFCI protected?
Old 06-25-2012, 02:51 PM   #6
Rewards Points: 172
I guess I shouldn't use that swithc for the fan AND the lights. Maybe for a fan/light combo but not for this setup?
Old 06-25-2012, 03:12 PM   #7
Lighting over a shower or tub does not require GFI protection unless called for in the instructions. I have never seen any that did. Exhaust fans and fan/lights are a different issue and do require GFI protection.
Old 06-25-2012, 03:17 PM   #8
Rewards Points: 172
The fan is just outside the shower stall. Maybe about a foot. Still no need?
I updated the diagram to reflect the AKDT63W light switch...
Even if I they do not need to be protected by the GFI is it ok if they are?
Old 06-25-2012, 03:25 PM   #9
As long as the fan is 1/16" outside the footprint it does not need GFI protection. You can install it if you wish.
Old 06-25-2012, 03:32 PM   #10
Rewards Points: 172
But no harm to be overly cautious? Also, just seems easier to wire that way...
Day & Night furnace wiring diagram Paul Dahlin HVAC 9 03-03-2011 09:08 PM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 08:51 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 08:59 AM
Celiera 18000 Split AC/Heatpump, power wiring diagram? trinhyulinh HVAC 2 08-03-2008 12:36 PM
