Proper Wire Gauges - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2012, 12:58 PM   #16
Upon further inspection, I traced the panel wire (12/2) to a junction box in the attic. From there it splits, one to an attic fan and the other to the bedroom - both 14/2 wires. Does this help? Or rather, how does this help me?
The Pave is offline   Reply With Quote
Old 12-10-2012, 01:06 PM   #17
Licensed electrician
Rewards Points: 1,744
Know you know that you definitely have a fire hazard and need to reduce the breaker to 15 amps.
Old 12-10-2012, 01:13 PM   #18
TTW
TTW's Avatar
Section 240.4(D)
requires an OCPD be NO LARGER THAN 15A for 14 AWG, 20A for 12 AWG, and 30A for 10AWG.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Proper way to protect wire ryan50hrl Electrical 41 08-23-2012 07:41 AM
Proper conduit for running wire in garage? mrrr0809 Electrical 5 08-05-2012 04:55 PM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Mixed Wire Gauges off of a 20A Circuit jfhanson4 Electrical 4 04-20-2011 06:46 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
