Proper Wire Gauges - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 11:38 AM   #1
proper wire gauges
I am trying to install an extra outlet receptacle in a bedroom. I intend to wire from a receptacle at the end of the line and add a receptacle on the adjacent wall. When i opened the outlet, I noticed 14g wiring but when I went to kill the power, the outlet is on a 20 amp circuit. I thought it should be 12g on a 20 amp circuit. If so, how dangerous is this? If it is OK, should I use 12g on the new outlet or stay with the same 14g?
The Pave is offline   Reply With Quote
Old 12-09-2012, 11:47 AM   #2
To make it safe change the breaker to a 15amp or change the 14ga wire to all 12ga. You should not mix 14ga and 12ga on the same circuit. I am sure someone else will ad to this and or say if I am wrong!
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
The Pave (12-09-2012)
Old 12-09-2012, 12:52 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
change the breaker to 15 amps, use 14 AWG for your new receptacle.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
micromind (12-09-2012), plummen (12-09-2012), TTW (12-09-2012)
Old 12-09-2012, 01:49 PM   #4
TTW
TTW's Avatar
It's ok to mix 12 and 14 gauge as long as the circuit breaker is 15 amps, the breaker needs to be sized for the smallest conductor.
Also, the wire in the panel should be labeled 15 amp circuit only.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
k_buz (12-09-2012)
Old 12-09-2012, 07:29 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
And you've gotten an electrical inspector to pass mixing 14/2 and 12/2 on a circuit?
Only time I ever mix wire sizes is on whips to terminate lighting
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-09-2012, 07:42 PM   #6
Licensed electrician
Rewards Points: 1,246
Care to cite the code that would allow this?
Old 12-09-2012, 07:50 PM   #7
plummen's Avatar
What do you use for whips when installing light fixtures?
I don't have code numbers memorized in my head like I used to but how about these 2?
410.117c and 240.5(B)(2)
those might have been revised ,but theyre the 2 that come to mind
Old 12-09-2012, 08:04 PM   #8
plummen's Avatar
lets see if this works
Old 12-09-2012, 08:37 PM   #9
Missouri Bound's Avatar
NO, it's not.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
Hardway (12-09-2012), plummen (12-09-2012)
Old 12-09-2012, 09:15 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by Missouri Bound View Post
NO, it's not.
Sure it is. It's not common practice, nor should it be, but it is perfectly legal.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Pudge565 (12-10-2012), TTW (12-10-2012)
Old 12-09-2012, 09:20 PM   #11
plummen's Avatar
When/where is it legal?
Old 12-09-2012, 09:25 PM   #12
k_buz's Avatar
As long as the circuit is fused for the smallest conductor, it is legal.
frenchelectrican (12-10-2012), Pudge565 (12-10-2012)
Old 12-09-2012, 09:30 PM   #13
NO, it's not.
I don't a lot, but I know mixing wire gage is not allowed! Thanks Missouri Bound:-)
Old 12-09-2012, 09:33 PM   #14
k_buz's Avatar
Then you are mistaken as well.
The Following User Says Thank You to k_buz For This Useful Post:
Old 12-09-2012, 09:35 PM   #15
k_buz's Avatar
Here's a perfect example...parking lot lights often leave the panel as 10's or even 8's, then half-way thru the circuit change to a smaller size wire. They might start out as 8's and end as 12's.
jbfan (12-10-2012)
Proper way to protect wire ryan50hrl Electrical 41 08-23-2012 08:41 AM
Proper conduit for running wire in garage? mrrr0809 Electrical 5 08-05-2012 05:55 PM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Mixed Wire Gauges off of a 20A Circuit jfhanson4 Electrical 4 04-20-2011 07:46 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
