Proper Way To Terminate Unused Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 12:27 PM   #1
Proper way to terminate unused wire
I have an baseboard heater that I want to remove from a room. The wire appears to come from a box that feeds multiple heaters in the room. I think the wire is stapled in places I cannot reach (and I might decide to put in a new heater in the future); so I want to safely leave it in place.
The heater that I want to remove is the only heater fed by this wire (the other two heaters are fed by the other branch from the original box.
The wire will have power when the other heaters are in use. I'm thinking the best way it to add a new plastic box in the wall to put the wire in (capped and taped). Is this the right approach and is there a minimum height from the floor that the box needs to be?
Thanks in advance!
cplbs is offline   Reply With Quote
Old 07-16-2013, 12:30 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
Taped is not necessary.
I place new boxes at the same height as the old boxes.
Put the cove on and be done.
Old 07-16-2013, 12:50 PM   #3
Thanks jbfan!
So just to be certain - it's ok to put cap the ends and leave them in a box even though they're still receiving power?
Old 07-16-2013, 03:35 PM   #4
jbfan's Avatar
Rewards Points: 246
Originally Posted by cplbs View Post
Thanks jbfan!
Yes.
If it makes you feel better, remove the connection from the other end.
Old 07-16-2013, 03:59 PM   #5
joed's Avatar
Rewards Points: 12,006
Putting live wires in an accessible covered box is the ONLY way to properly terminate them.
If you disconnect the cable at the other end so the wires are no longer live you can do whatever you want with them.
Proper conduit for running wire in garage? mrrr0809 Electrical 5 08-05-2012 05:55 PM
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
