Proper Way To Terminate Overhead Wiring At Weather Head Feeding A Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 09:38 PM   #1
Proper way to terminate overhead wiring at weather head feeding a detached garage
I have a detached garage that is fed with a 30amp 240V 2-pole circuit using #10 wire attached to a steel messenger cable. However, I think the way the overhead wires are connected at the weatherhead is ugly (see picture).
Is this even code-complient, and is there a more "aesthetically pleasing" way
these wires can be connected?
Thanks for any suggestions.
JackDeth is offline   Reply With Quote
Old 08-26-2013, 10:01 AM   #2
Rewards Points: 156
Looks fine from this vantage point. But who knows what the connection is, if its covered in tape.
The wires are in this position to allow water to drip away from the conduit and structure.
This is called a drip loop. Not the best of jobs as I would have made an actual loop.
I see zero issue other than a better drip loop and would like to know what is connecting those wires under the tape.
Old 08-26-2013, 10:07 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Looks like wire nuts taped up.
Some simple butt splices would work, just keep them from being in the bottom of your drip loop.
wirenut1110 is offline   Reply With Quote
Old 08-26-2013, 01:41 PM   #4
Rewards Points: 760
am i looking ok, Ground wire seems to be connected to 2 wires in the pole probably a ground and a neutral
carmusic is offline   Reply With Quote
Old 08-26-2013, 03:15 PM   #5
carmusic: The picture was taken with a zoom lens, so it flattens the image a bit, but there are 4 separate wires running from the breaker in the main panel all the way to the garage (ground, neutral, 2 hots). They are feeding a subpanel, and the neutral is kept isolated from ground in the panel.
wirenut1110: yes, that is right, those are wirenuts with some tape on top. They do appear to be gel-filled. I guess a butt-splice would look a little nicer (IMO). I wasn't sure if those were code though (I know they are very common on 12V car electrical systems).
On a related question, if you look at the picture full size, you can see how the clear plastic coating is deteriorating on the wires, but the colored insulation seems to be fine. Is this normal, or was the wrong type of wire used?
Old 08-26-2013, 04:10 PM   #6
Rewards Points: 510
Well, since you asked, I doubt, very seriously, that individual conductors were ever allowed to be secured to a messenger like that.
But hey, I've been wrong before. Seems to me those wires don't have any sunlight resistivity.
Old 08-26-2013, 04:52 PM   #7
What type of wire would you recommend?
Old 08-26-2013, 05:26 PM   #8
Rewards Points: 510
It's there and it looks like it's been there for a while so, I wouldn't worry about it.
I wouldn't know what the code was when that was installed.
The smallest messenger supported cable you can get, from what I've seen, is a #6 quadraplex code name Chola.
Electrical Wiring for Separate Garage HomeGuy2 Electrical 11 03-15-2013 10:50 PM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
wiring detached garage psteinberg Electrical 3 12-09-2011 04:50 PM
Updating wiring for detached garage question inlet510 Electrical 13 09-23-2011 02:22 PM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
