Proper Way To Switch A Ceiling Light. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 03:44 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Proper way to switch a ceiling light.
I will probably never understand why, but in my bedroom I have:
1: A light switch immediately to the left when you walk in which does ....... nothing!
2: A light in the ceiling in between the "his n' her's" closets with a pullstring!!!
It's upstairs so it would be an easy climb into the attic to get above it all. What I'd like to do is replace the ancient pull string lamp with a new one and wire the switch to turn it on.
I was thinking about running romex from the switch to the lamp and just interrupting the hot phase before it goes through the ceiling.
Anything I am missing here?
CoconutPete is offline   Reply With Quote
Old 06-10-2010, 03:50 PM   #2
Not sure about your code, but just note that some codes have special rules for allowable lighting in a closet, not sure if you meant you are installing in a closet area or not though.
Does that existing switch get power at all? It is possible that it does actually control something but that the switch is broken and always 'on'. Just one thought. Anyways, it doesn't sound like you are missing anything at all.
Troglodyte is offline   Reply With Quote
Old 06-10-2010, 04:35 PM   #3
Rewards Points: 504
No, I might have mis-worded that. The light isn't actually going in the closet, it's out in the bedroom between the two big closets in the room.
I'll admit, I haven't pulled the wires for the switch yet and seen if there is power in them, but that is next. The only thing I can think of is that maybe it was for the top half or lower half of one of the outlets at one point and maybe the outlets got changed so the outlet that was switched is now getting constant power from the two of them now being connected.
Old 06-10-2010, 04:45 PM   #4
Rewards Points: 1,448
To use the existing switch you need to figure out whether it really used to control the light. Start by turning off the power and disconnecting one wire from the existing switch. Turn the power back on for a moment. If the light still works then the old switch controlled something else (or nothing else).
The easiest way to convert a pull string light to a wall switched light is to run a (2 conductor) cable from the light down to the desired switch location.
Disconnect the black wire (the hot power feed) from the light and connect the new cable black wire to the light in its place. Connect the old black wire to the other wire in the new cable.
If you replaced a receptacle that used to have just the top half controlled by the switch and forgot to bend and break off the little tab between the gold screws, then both halves will be live all the time and it will look as if the switch is stuck on.
Old 06-10-2010, 04:57 PM   #5
Rewards Points: 504
Cool, that sounds right in line with everything I thought.
I have a sliiiight case of OCD so i think i'll have to pull the outlets and check them just for peace of mind's sake. If it really turns out the switch does nothing then i'll probably cap the wires and run fresh ones to the ceiling light.
Old 06-10-2010, 05:55 PM   #6
Just call me Andrew
Rewards Points: 1,020
Why dont you just turn the switch off and see which outlets don't work? Why pull the outlets out?
If you do that, try the top and bottom sockets on the outlets. The switch may control only one of them
Andrew
secutanudu is offline   Reply With Quote
Old 06-11-2010, 08:19 AM   #7
Like another poster said, someone may have replaced the outlets and not broken off the tab. The switch then would do nothing as there would be power to top and bottom of the receptacle at all times.
Taking out the receptacle is the only way to see if the tabs are there or not.
tdeg807 is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
ceiling fan works, but light doesn't egildone Electrical 2 09-22-2009 12:20 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
