Proper Way To Splice Wires - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 08:59 AM   #31
Learning by Doing
Leah Frances's Avatar
Originally Posted by Wildie View Post
One point that I would like to say. The ones that I bought were bot used for electrical connections. I needed to splice some aircraft cable, used for an awning and they worked well for this purpose.
Way to violate their UL listing, Wildie.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-24-2011, 09:01 AM   #32
I ask the impossible!
Rewards Points: 712
Don't Canadians also have to bond their ground to their plastic junction boxes?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-24-2011, 09:29 AM   #33
Just call me Andrew
Rewards Points: 1,020
Then how many twists are required before applying the wire nut and does this apply to all brands?
There's no simple answer to that...it really just goes by feel.
It would depend on number/size of conductors, the size wirenut, etc.
Andrew
secutanudu is offline   Reply With Quote
Old 05-24-2011, 11:25 AM   #34
Rewards Points: 246
Originally Posted by Bunited2 View Post
The one thing about using tape, is that wire nut is definitely not coming off until it's supposed to.
I would not count on it.
I have taped wire nuts on machinery that is subjected to continuous vibration because wire nuts do vibrate loose on occasion.
If you need to use tape you are using the wrong connectors for the application. Motors are a good example. While I use wirenuts on small motors I use other approved means of connection on larger equipment. The only time I see tape as required is with split bolts.
No twisting is required when using wirenuts.
Old 05-24-2011, 11:29 AM   #35
Learning by Doing
Nooooooooo!!!! Not the twist first or not to twist first debate.
Can we just agree that people do it both ways? And that both sides think they are right. Please?
Old 05-24-2011, 11:31 AM   #36
Just call me Andrew
I misread that question - i thought he was asking how many times you have to twist the wirenut.
Andrew
Old 05-24-2011, 12:31 PM   #37
The code for retractable awnings only require adherence to the Chinese Export Regs. and you know how stringent that would be.
The Following User Says Thank You to Wildie For This Useful Post:
Leah Frances (05-24-2011)
Old 05-24-2011, 12:33 PM   #38
Correct! It was a trick question!
Old 05-24-2011, 12:36 PM   #39
OK! Here's another question? If you are in the Southern Hemispere, in a place such as Australia, are wire nuts twisted in a counter-clockwise direction when installing?
Old 05-24-2011, 02:00 PM   #40
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
I used to pretwist my wires and was glad to find out here at one point that I don't have to. My fingers no longer bleed after electrical work.
If you are really scared about a loose connection just fill the box with Great Stuff and nothing is ever going to move. (just kidding.. DO NOT do that lol)
Old 05-24-2011, 02:02 PM   #41
Wire Chewer
Rewards Points: 138
The easiest way to know is to flush the nearest toilet. You have to turn in that direction.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 05-24-2011, 06:29 PM   #42
Especially if you've been eating Mexican!
Old 05-24-2011, 07:57 PM   #43
Missouri Bound's Avatar
Fred. Wire nuts are an approved fastening device, tape is not. But tape is often used outdoors to help prevent corrosion in the wire nut. Tape is also used when vibration is a concern. If moisture is an issue, there is a product called Scotchcote.
Old 05-26-2011, 02:42 AM   #44
Bunited2
Bunited2's Avatar
Send a message via Yahoo to Bunited2 Send a message via Skype™ to Bunited2
I come back after 2 days and you're all still talking about nuts?
Bunited2 is offline   Reply With Quote
The Following User Says Thank You to Bunited2 For This Useful Post:
Ron6519 (05-27-2011)
Tags
junction , splicing , tape , wires
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 06:38 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 11:31 AM
Re-routing wires in attic blakstarr Electrical 10 11-24-2008 05:57 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
