Proper Way To Splice Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 08:02 PM   #1
Proper way to splice wires
Hi all,
I am currently rewiring a big part of my house to replace old ungrounded cables with proper grounded wires. Last week I had the opportunity to ask an electrician a few questions; one of those was "Is it ok to splice wire in a junction box with electrical tape ?" His answer was, "Pretty much anything reasonable is ok within a junction box".
But the more I read, to more it seems it's not ok. Problem is I already have quite a bit of work involving taped splice done. So here is my question - Is it really a problem or should I leave it like this ?
I plan to have it inspected at the end to prevent any insurance related problem in the case of an accident (even though the guy inspecting it will probably be the guy who told me it was fine).
The wire is all 14. I live in Quebec, Canada.
Thanks !
Fred_ is offline   Reply With Quote
Old 05-22-2011, 08:07 PM   #2
Framing Contractor
Rewards Points: 100
Why on earth would you not use wire nuts? Am I misunderstanding something here?
sixeightten is offline   Reply With Quote
Old 05-22-2011, 08:21 PM   #3
Licensed electrician
Rewards Points: 1,054
Twist-on connectors (wire nuts) or something like the Ideal push-ins are the correct way to ensure a tight connection. Tape is definitely not the way to make a secure problem free splice.
Old 05-22-2011, 08:36 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Just make sure the junction boxes are easily accessible.
You'll need to get to them in a few weeks from now.
Old 05-22-2011, 08:40 PM   #5
IBEW Electrician
No that is not the proper way to splice, you should be using wire nuts.
Scott3229 is offline   Reply With Quote
Old 05-22-2011, 08:54 PM   #6
Framing Contractor
Rewards Points: 100
The guy who told you that you could is no electrician. Maybe he is an elect ition cause he told u lies.
Old 05-22-2011, 09:02 PM   #7
Haha!
he is a proper electrician with licenses an' all ! He seemed competent apart from that answer (or maybe it's common practice around here ?).
I should have mentioned that my wires are tightly twisted together under the tape. But still, If I must, I will redo those darn connections.
However, since my house is fairly old (1949) a lot of the original splices are tape only and still good after 62 years.
So, is it a total no go or more like a "it will fail earlier than wirenuts ?"
Thanks again !
Old 05-22-2011, 09:07 PM   #8
Learning by Doing
Leah Frances's Avatar
Those old splices may not just be taped. They are likely soldered also.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-22-2011, 09:08 PM   #9
While we're at it, another quick question,
Is it ok to run two wires through one hole in a junction box ? I have only four holes and need 5 wires in one spot. I could do otherwise but running two wires in one hole would save me 5 joist holes !
Old 05-22-2011, 09:10 PM   #10
Some are, some are not, I took a few apart to ground outlets and some were just twisted.
Ain't that twisted ! :P
Old 05-22-2011, 10:05 PM   #11
Twisted with tape isn't adequate in Ontario and I doubt its legal in QC either.
Splices require a certain amount of mechanical pressure that is achieved by the use of wirenuts. Merely twisting isn't sufficient.
I have made splices for street light cables. We used Burndy mechanical connectors. These were wrapped in rubber tape, followed by electrical tape and then coated with 3M Scotch Coat.
This is the only way that we were allowed to tape electrical connections.
Old 05-23-2011, 09:17 AM   #12
Rewards Points: 3,130
Are you sure your "electrician" didn't misunderstand your question? I have seen electrical tape in junction boxes many times, but it was always wrapped around the wire nuts. Why, I don't know.
Old 05-23-2011, 10:18 AM   #13
I was pretty clear about it as I was a bit doubtful so I don't think he misunderstood...
Old 05-23-2011, 01:26 PM   #14
Rewards Points: 64
Originally Posted by Fred_ View Post
Haha!
Thanks again !
Have you ever witnessed a house fire? Electrical tape was never an approved connector.
Years ago solder was used and then taped. The wirenut was then invented and the use of tape has all but disappeared. Thankfully!
Hes a hack. I would not let him do any work for me.
Old 05-23-2011, 01:35 PM   #15
Originally Posted by J. V. View Post
Have you ever witnessed a house fire? Electrical tape was an approved connector.
How can tape inside an electrical metal box cause a fire ? I thought fire were mostly due to wrong wire gage or junctions outside of metal/plastic boxes.
Anyhow, I redid the taped junctions with wirenuts but some of the old stuff I often don't have enough loose wire to redo...
I will have him do the inspection only, I will have an easier time The work I do myself anyway.
Another question, what do you guys think of plastic boxes ?
Tags
junction , splicing , tape , wires
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 04:00 PM
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 07:38 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 12:31 PM
Re-routing wires in attic blakstarr Electrical 10 11-24-2008 06:57 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
