Proper Way To Secure Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 06:47 PM   #1
Rewards Points: 27
Proper way to secure romex
I have some remex coming from my floor joists. What’s the best way to secure the wires that run along the panel (the 12ga on the sides)? Would some zip ties anchored to the concrete bet sufficient?
Here's a pic:
Yes, I know there is a typo in the title, but I don't think I can change it now.
marly is offline   Reply With Quote
Old 08-22-2012, 06:51 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Here's a pic:
http://www.cobaltfactor.net/IMG_0866.jpg
Plywood behind the panel would have helped greatly, would have given you a nice surface to staple to... You need straps along the top as well... within 12" of the panel. Do whatever you have to to secure the cables...
Old 08-22-2012, 06:57 PM   #3
Rewards Points: 27
They didnít put plywood behind the panel when they built the house, although it would have been nice. I donít mind putting a couple anchors through the concrete. - It isnít much to drill some holes.
Old 08-22-2012, 07:00 PM   #4
E2 Electrician
you can use tyraps with the holes in them to secure the cables...
Personally, whoever did that install.... eh... not pretty.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (08-22-2012)
Old 08-22-2012, 07:02 PM   #5
Licensed electrician
Rewards Points: 1,478
You could mount a piece of 2x4 flat against the wall and staple the wires to it.
I would also move the cables into the sides up to the top of the panel.
Old 08-22-2012, 07:02 PM   #6
Rewards Points: 27
Whatís not pretty about it? The four 12ga romex, or the whole thing?
Old 08-22-2012, 07:04 PM   #7
E2 Electrician
What’s not pretty about it? The four 12ga romex, or the whole thing?
beauty is in the eye of the beholder, but its pretty ugly as it stands, but could be made a lot nicer with proper strapping... I would have a hard time walking away from that and then sending someone a bill.
Old 08-22-2012, 07:16 PM   #8
Rewards Points: 27
I would move the cables on the sides to the top, but all of the knockouts are full on the very top. The top on the sides have knockouts for 1Ē or greater. I could move the cables up slightly, but it would only be a few inches or so.
I don't mind making it look a little more neat with some suggestions (baring ripping the whole thing out).
Old 08-22-2012, 07:38 PM   #9
That doesn't look like enough cables to use all the KOs on the top. Also many cable clamps are good for two cables.
Old 08-23-2012, 07:01 AM   #10
Rewards Points: 166
My setup was kind of a mess when I moved in. Especially the coax cable that looked like a ratsnest at the upper left corner of the panel near the signal amplifier.
I mounted a piece of plywood to the adjacent wall and moved the signal amplifier and phone modem to it along with some power adaptors. Not saying mine is the best it could be but looks better than before.
The after picture was taken from the side view.
Proper way to secure romex-before.jpg   Proper way to secure romex-after-20side.jpg
Minus08 is offline   Reply With Quote
Old 08-24-2012, 09:24 PM   #11
E2 Electrician
Try to make it look like this....
Old 08-25-2012, 01:26 PM   #12
Rewards Points: 164
I thought you weren't supposed to wire tie wires together into bunches....or is that just in the box?
ryan50hrl is offline   Reply With Quote
Old 08-25-2012, 01:27 PM   #13
E2 Electrician
In the scenario in the picture, i'm under the derating requirement, so its a non issue...
Old 08-25-2012, 01:40 PM   #14
Rewards Points: 1,452
You can either slide plywood behind it or just cut wood into a u shape and slide it around it before fastening it to the wall.
mikegp is offline   Reply With Quote
No Romex underground ... sirsparksalot Electrical 46 10-08-2014 04:41 AM
Romex Junctions fsae0607 Electrical 7 03-12-2011 12:04 PM
Is Romex 8/2 considered a three wire system? safetyfirst Electrical 3 10-17-2010 07:23 PM
What do you sparkies do about ac disconnects and romex connectors? rgsgww Electrical 19 03-18-2009 07:05 AM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
